Transmission - Mustang Evolution
Old 07-08-2012, 09:39 PM   #1
Gobabygo67's Avatar
Transmission
So recently my trans won't let me go into third gear, whenever I try to it makes a bad noise and pops it back out. I've looked at my throw out bearing and it was great. Any suggestions?
Gobabygo67 is offline   Reply With Quote
Old 07-08-2012, 10:23 PM   #2
Blogger
99ford's Avatar
How is the fluid?
Old 07-08-2012, 10:31 PM   #3
1996mustang's Avatar
Manual? I would say either 2 things both happened to me......synchro or the tranny mount.
Old 07-08-2012, 11:48 PM   #4
Matticus's Avatar
Got my bet on the synchro
Matticus is offline   Reply With Quote
Old 07-08-2012, 11:54 PM   #5
Re: Transmission
I def agree....
southernstang00 is offline   Reply With Quote
Old 07-09-2012, 12:36 AM   #6
Gobabygo67's Avatar
May sound stupid but what do you technically mean by "synchro"? Is that related to the forks?
---------- Post added at 12:36 AM ---------- Previous post was at 12:35 AM ----------
Yes it's a manual btw
Old 07-09-2012, 02:02 AM   #7
Re: Transmission
I got this off another website but they were referring to the first gear syn but its the same concept.
yeah basically between each cog in the gear box is a small synchronizser which is usually known as a synchro-mesh. It is called this becuase as you go to slide from one cog in the gear box to the next cog (i.e changing gear) the 2 synchros mesh with each other so the selected cog and the cog you are about to change to spin at the same speed. This enables you to have a smooth gear change. When they are not spinning at the same speed and you go to change gear you can hear the synchros grind on each other.
11:22 AM
