How to remove radio/ac bezel - Mustang Evolution
Old 07-09-2012, 10:42 AM   #1
9tee7pony's Avatar
Just bought a Kenwood head unit and can't remove the bezel to get the old stereo out. This is where I am. The top is easy, but the bottom is solid as a rock and I don't see any screws. Need help fast
ID:	58196   Click image for larger version
9tee7pony is offline   Reply With Quote
Old 07-09-2012, 12:45 PM   #2
Mile high JDF's Avatar
There is two torx screws underneath the upper radio
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 07-09-2012, 12:56 PM   #3
If you're talking about just the bezel just pull a little harder. It just pops off, no trick to it
Old 07-09-2012, 05:03 PM   #4
9tee7pony's Avatar
I got those and with a little more research and looking there is on way in the back that is a pain in the @$$ to get to. I'll play with it more in the morning.
Old 07-09-2012, 06:54 PM   #5
There shouldn't be. After you take those two out it should come out with a little pulling like LowFlyn said
Old 07-09-2012, 07:12 PM   #6
runvsofthisbull's Avatar
Re: How to remove radio/ac bezel
Yea just pull harder. Use both hands and secure the bottom and give it a few quick jerks and it should come off. Its secured with plastic pins/spikes that go into holes in the metal/plastic support behind it. That should be it.
2002 True Blue V6 to GT Vert
16.1@86 as an auto 3.8
Old 07-09-2012, 07:29 PM   #7
9tee7pony's Avatar
I've taken a screw driver to the part that is holding on and if I pull any harder the trim piece will snap. That screw is attached to the entire piece and is right where it is a pain in the tush.
08:13 PM
