Going to pick up my 5 speed tranny!!! - Mustang Evolution
Old 07-09-2012, 05:53 PM   #1
Bballing0416's Avatar
Hey everybody!
Just wanted to let you know that im going to be buying a t3650 with everything i need for the swap! Im super excited to convert my auto to manual!!!
Bballing0416 is offline   Reply With Quote
Old 07-09-2012, 05:58 PM   #2
deadsp0t's Avatar
Nice! A CL find? eBay?
That's unimpressive
Old 07-10-2012, 09:36 PM   #3
Craigslist....local pick up so i can save on shipping
Old 07-11-2012, 06:53 AM   #4
MustangGT02's Avatar
Re: Going to pick up my 5 speed tranny!!!
Sweet, I am also planing to do this a swap on my 02 GT. Can you please make a list of every thing you need. Also how do you know what flywheel to put on? How do you know which flywheel to get also?
MustangGT02 is offline   Reply With Quote
Old 07-11-2012, 03:41 PM   #5
Yep ill get you that list once i have everything....and he is giving me everything including the flywheel....it is in his car now and he gave me a ride to show me how it goes through the gears so he's gonna rip it out over the weekend and ill get it
Old 07-11-2012, 04:05 PM   #6
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
Nice! I just did a 5 speed swap in my 90. Love being able to control the gears! GL!
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 07-11-2012, 05:27 PM   #7
Was it a hard job?
Old 07-11-2012, 06:03 PM   #8
Pete Jones
Originally Posted by Bballing0416
Was it a hard job?
I think the hardest part was the removing of the pedals and installing the manual pedals. Other than that it was pretty easy. Trans lines I tried to save but just ended up breaking them to get them out.
Everything else came out pretty smooth. Just take your time with it. Took me about a week with basic hand tools, a jack and jack stands. I would suggest draining the auto trans fluid so when you pull the dipstick tube it doesn't come pouring out.
I'm not sure about the neutral safety switch in your car but on nine I just cut the plug off the aod and put 2 wires together to make them a closed loop then just spliced the other 2 into the manuals safety switch on the side of the trans.
Just make sure your getting EVERYTHING to make it look factory. You wouldn't be able to tell my car was originally an auto unless you crawled underneath and saw the spliced neutral plug. I even have a working neutral safety switch do you have to press the clutch to start the car.
90 LX hatchback
89 LX Notchback
Old 07-12-2012, 08:58 AM   #9
Thanks! Man you really got lucky finding some one with it in there car still so you know it works.
Old 07-12-2012, 09:05 AM   #10
Lorraine's driver
ab_mach1's Avatar
Hey everybody!
Awesome bro! Post experience and pics as you progress.
Instagram: @ab_mach1
Old 07-12-2012, 11:21 AM   #11
Yea the guy is doing a terminator motor/trans swap
Old 07-23-2012, 07:41 PM   #12
Well have you put it in yet, I just ordered a complete conversion kit for mine and have just about no idea what I'm doing.
Old 07-27-2012, 11:17 PM   #13
Nope i havent started yet but i will soon...about 10hour job
Old 07-30-2012, 06:56 AM   #14
CodyNelson's Avatar
Region: West Virgina
updates?
Old 08-07-2012, 12:23 PM   #15
Old 08-08-2012, 12:01 PM   #16
Well I'm going to lift mine up tomarow and get started, i still don't have the pedal assembly and flywheel. The fly wheel is going to be freshly resurfaced when I get it. It looks like you may need to steal the end off a manuals drive shaft. My kit came with a complete drive shaft from a manual so something must be different there.
Old 08-08-2012, 12:35 PM   #17
Yea my driveshaft is in my garage....i still need the pedal assembally and clutch cable then ill be ready to go
Old 08-08-2012, 12:44 PM   #18
Rm360's Avatar
Do you need to change the PCM to do the swap and if not how do you eliminate the auto shifts points from the pcm
Old 08-08-2012, 02:07 PM   #19
BeasGT's Avatar
I'm converting mine too!
BeasGT is offline   Reply With Quote
Old 08-08-2012, 02:26 PM   #20
I have a sct from AM, I called bama and they said to request a new tune and put in the comments that you have swapped.
Old 08-08-2012, 04:13 PM   #21
Yea my handheld tuner can change anything computerwise
Old 08-08-2012, 04:29 PM   #22
Rm360's Avatar
Thanks I just got done reading that you can retune for the swap , are you guys modifying your wire harness or did you get the harness with the trans? And aren't the trans sensors different between the auto and manual also?
Old 08-08-2012, 09:33 PM   #23
My kit came with a wire harness.
Old 08-08-2012, 11:07 PM   #24
I talked to a guy who specializes in stangs and he said there is no need for a wire harness
Old 08-09-2012, 08:20 AM   #25
Lorraine's driver
ab_mach1's Avatar
Are you gonna get a Steeda clutch quadrant and firewall adjuster? I hear the plastic quadrant crack easily. Mine hasn't yet, but this is my next purchase. I thought since your swapping, now is a good time to do it.
http://www.americanmuscle.com/stqureclqu.html
http://www.americanmuscle.com/stficaad.html
I thought Steeda made a complete kit, but I didn't see it on AM.
Old 08-09-2012, 08:25 AM   #26
Thanks for the advice! I probably will go with an aftermarket clutch quadrant
Old 08-11-2012, 05:25 PM   #27
Well sorry, its completely different and you will need one for a 5 speed. Just took my auto one out.
Old 08-12-2012, 03:25 PM   #28
Would you be able to take pics of your progress
Old 08-12-2012, 04:43 PM   #29
I have started a thread on the steps, my dad and I are both working on the car still but once we are done we will finish the instructions. Hopefully the full instructions will be wrote by next week.
Old 08-12-2012, 09:44 PM   #30
What would you say was the toughest part so far
Old 08-12-2012, 09:52 PM   #31
Pedals and getting the manual to go into the engine and clutch ext. Its the small stuff that can get you, we got the manual lined up and went to get the top two bolts in and noticed one of the wires for the exhaust sensors was in the bellhousing so we had to take it off, pull the wire and connector out and start all over again.
Old 08-14-2012, 04:07 AM   #32
Rm360's Avatar
@Bballin , you have a FI set up don't you? I'm curious to know as to why you are swaping to a manual trans the auto is much more better for FI applications
Old 08-14-2012, 07:48 PM   #33
Yea i do have FI.....just 5 speeds are a lot of fun to drive and i can drop the clutch and slam through the gears!
Old 08-14-2012, 08:21 PM   #34
Lorraine's driver
ab_mach1's Avatar
+1
Old 08-14-2012, 08:30 PM   #35
Well my swap is almost done, the car drives good so far, I still have to get the cover over the clutch fork and take out the tricky auto trans fluid lines that are in the radiator pretty good.
06:48 AM
