That doesn't sound good! - Mustang Evolution
Old 07-11-2012, 05:55 AM   #1
daddydigest's Avatar
So, on my way to work this morning I heard a small ticking and then it became a loud ticking. The next thing that I know I pulled over, looked under the hood, and found a torn up in injection coil and spark plug laying on the top of my motor.
I need y'all's opinion. Is this an easy fix? Can I go buy a replacement coil at the local auto parts store and then put a new one in there along with a new spark plug? Or is it better to take it to my usual shop and just let them do it? I noticed that the spark plug had some of the porcelain chipped on it. Is that still down in there or did it probably blow out like the rest of it?
Thanks for the comments and suggestions in advance guys!
daddydigest is offline   Reply With Quote
Old 07-11-2012, 06:32 AM   #2
02PONY's Avatar
I'd check the threads in the head if there good just put a new plug in it. If the threads are messed up you'll need to get a heli-coil kit and re tap it never personally done it but heard its a pita
02PONY is offline   Reply With Quote
Old 07-11-2012, 06:58 AM   #3
It's not me, it's you.
primer2tone's Avatar
If it is repairable, you might want to check the rest of your plugs and make sure they're not backing off.
Old 07-12-2012, 05:53 AM   #4
Thanks guys for those suggestions! I think I am going to take some time on Friday to go ahead and change all of my spark plugs out and replace the damage coil. Here's another question though:
What are some suggestions on spark plugs? Brands? Should I stay with Motorcraft? Or should I go with something else?
And what's the difference between things like copper, platinum, double platinum, iridium? Are there any certain types or brands that I should stay away from? Thanks again in advance!
Old 07-12-2012, 06:47 AM   #5
Region: West Virgina
I have the diamond e 3 and love them
Mustangnutz is offline   Reply With Quote
Old 07-12-2012, 06:54 AM   #6
02PONY's Avatar
Motorcraft
Old 07-12-2012, 06:55 AM   #7
Horseplay's Avatar
Originally Posted by 02PONY
Motorcraft
^ + 10000
these worked wonders when i switched to these
Low2v
Old 07-12-2012, 07:04 AM   #8
scottiep101's Avatar
Motorcraft
Motorcraft all the way!!!!!
scottiep101 is offline   Reply With Quote
Old 07-12-2012, 07:30 AM   #9
Motorcraft Platinum? Should I by a whole new set of coils also? Like the accel ones?
Old 07-12-2012, 07:35 AM   #10
Just ask for the factory plugs
Old 07-12-2012, 07:46 AM   #11
02PONY's Avatar
No regular motorcraft are fine and just replace the damaged coil unless u have money to waste on an entire set
Old 07-12-2012, 09:49 AM   #12
jjsg09's Avatar
I just wrote on another thread about this same thing. Warning people if they hear that sound what it is. That sux
Old 07-12-2012, 09:55 AM   #13
deadsp0t's Avatar
Don't buy Accel anything, ever. If you want aftermarket ignition parts MSD is the only way to go.
That's unimpressive
06:32 AM
