Ignition problems - Mustang Evolution
Old 07-11-2012, 06:52 PM   #1
Kotty4643's Avatar
Ignition problems
I have a 96 mustang and the ignition is messed up I can start the car with a key but when I turn the key off the car stays running I have to manually turn the car off with the bar that sticks out of the ignition box I need to know what I have to do or replace in the steering column to make the key not only start the car but turn the car off correctly some one please help
Kotty4643 is offline   Reply With Quote
Old 07-11-2012, 09:09 PM   #2
1996mustang's Avatar
Check the lock cylinder is what i suggest
07:16 AM
