Camahafts? Help - Mustang Evolution
Old 07-12-2012, 11:53 AM   #1
Illdrag's Avatar
Camahafts? Help
Looking for the long duration and high lift cam. What's the biggest you can use on stock heads and stock valve springs? If its less than 275/275 dur and 500/500 lift what head set up will I need to run..
Illdrag is offline   Reply With Quote
Old 07-12-2012, 12:52 PM   #2
Re: Camahafts? Help
I got away with the Stage 2 extreme energy cam by comp cams on stock stuff...had no issues. I can get a link to the exact one if you want me too...
southernstang00 is offline   Reply With Quote
Old 07-12-2012, 01:13 PM   #3
CodyNelson's Avatar
Region: West Virgina
Re: Camahafts? Help
Comp 270s are about as big as you wanna go on a stock setup
Old 07-12-2012, 01:27 PM   #4
Re: Camahafts? Help
The stage two energy cam is about somewhere in there isnt it? I cant remember...
Old 07-12-2012, 01:59 PM   #5
CodyNelson's Avatar
I believe they are the same specs
Old 07-12-2012, 02:08 PM   #6
Re: Camahafts? Help
ohok,
Old 07-14-2012, 11:14 AM   #7
Illdrag's Avatar
Yea send a link, thanks its greatly appreciated
Old 07-14-2012, 11:40 AM   #8
Re: Camahafts? Help
These are the ones I went with first and used stock springs, and just a tuner with a tune from bama and had no issues what so ever. But if I were to go back and do it all over again I would have bought the bee hive springs and replaced them though.
COMP Cams: Xtreme Energy™, XE268H <BR> Mild Street Performance, Noticeable Idle
« Cobra | gears »
04:03 PM
