missing and low pressure when clutch is in,please help - Mustang Evolution
Old 07-12-2012, 05:29 PM   #1
redstang98's Avatar
someone please help before i send it off a cliff.
new plugs ,wires and coil packs good. motor skiping or missing and low pressure when clutch is engaged
---------- Post added at 05:29 PM ---------- Previous post was at 05:22 PM ----------
only stays running when i have the vemon 400 on
redstang98 is offline   Reply With Quote
Old 07-12-2012, 06:37 PM   #2
What's Vemon 400 ? If it's an alarm system then I think that may be your problem
96gt014.6 is offline   Reply With Quote
Old 07-12-2012, 08:06 PM   #3
redstang98's Avatar
Not alarm . It controls mas and throttle body in comp.
Old 07-12-2012, 08:30 PM   #4
jjsg09's Avatar
Sounds like a vacuum leak or pcv valve clogged. Could also be the idle air control valve.
Old 07-12-2012, 08:38 PM   #5
redstang98's Avatar
PVC valve is on the driver side valve cover?
Old 07-12-2012, 08:47 PM   #6
jjsg09's Avatar
Should be on the passenger side under cold air intake
Old 07-12-2012, 08:58 PM   #7
redstang98's Avatar
Then what that on driver side . Im electronic not mechanical
Old 07-12-2012, 09:00 PM   #8
redstang98's Avatar
Hey do you know what this is thats at my finger
Old 07-14-2012, 04:01 AM   #9
LAS97GT's Avatar
Crank case vent
---Las97GT
Old 07-15-2012, 07:06 PM   #10
redstang98's Avatar
Replaced all that and still the same what is that line that is black with red stripe on it going out back bottom on the pluiem1/4 hose ?
---------- Post added at 07:06 PM ---------- Previous post was at 07:05 PM ----------
About to put sea foam in it to c if it helps
12:22 PM
