Does anyone know what this is - Mustang Evolution
Old 07-13-2012, 09:29 AM   #1
redstang98's Avatar
Need to know what this is?
redstang98 is offline   Reply With Quote
Old 07-13-2012, 09:43 AM   #2
deadsp0t's Avatar
Ummmm.. Going to need a pic!
That's unimpressive
Old 07-13-2012, 09:51 AM   #3
redstang98's Avatar
Trying now
Old 07-13-2012, 09:52 AM   #4
I don't know what that is but uh I was say it needs to be plugged in that's for sure
96gt014.6 is offline   Reply With Quote
Old 07-13-2012, 09:53 AM   #5
redstang98's Avatar
Does this look bad
Old 07-13-2012, 09:55 AM   #6
Picture focused on your tb but from the looks of it...yeah that doesn't look to good
Old 07-13-2012, 10:40 AM   #7
redstang98's Avatar
Sometimes it will try to run good but goes back to **** fast .
---------- Post added at 10:28 AM ---------- Previous post was at 10:01 AM ----------
isnt that my pvc
---------- Post added at 10:40 AM ---------- Previous post was at 10:28 AM ----------
staff do you know what that is i cant find where it would plug in at
Old 07-13-2012, 10:49 AM   #8
It's not me, it's you.
primer2tone's Avatar
Look on your passenger side valve cover.
Old 07-13-2012, 11:00 AM   #9
Arron's racecar's Avatar
Region: Nevada
isnt that my pvc
That looks like a PCV to me someone correct me if I'm wrong but I believe you're having some blow by and should probably be replaced.
2004 GT current mods : CAI, BBK Short throw shifter TB and UDPs, SCT x3/SF3 with BAMA Perfomance tunes Roush body kit, roush side skirt exhaust and paint.
Arron's racecar is offline   Reply With Quote
Old 07-13-2012, 11:03 AM   #10
taylor98gt's Avatar
Re: Does anyone know what this is
+1 he said it all lol, get that replaced and you should be good.
taylor98gt is offline   Reply With Quote
Old 07-13-2012, 11:32 AM   #11
redstang98's Avatar
Would that make me have low pressure and fill like it missing . I have been pumping a lot of money in this car
Old 07-13-2012, 11:38 AM   #12
Region: Nevada
The PCV is a inexpensive part and your local auto parts store should have it in stock and yes a bad PCV can make the car run poorly
Old 07-13-2012, 12:01 PM   #13
redstang98's Avatar
So cleaning it wont make a difference? And is there anything else . Does the line get clogged at intake
---------- Post added at 12:00 PM ---------- Previous post was at 11:54 AM ----------
do u know what that offer part is
---------- Post added at 12:01 PM ---------- Previous post was at 12:00 PM ----------
cant find a spot for it to go to
Old 07-13-2012, 12:30 PM   #14
The pvc plugs into the pass valve cover and then a rubber tube should run to the bottom, front of the plenium. As far as the first picture, are you referring to the tube your hand is on?
Go to autzone or such and as the person that works there that you need a PVC valve your year of mustang GT, it should only cost like three bucks or so.
southernstang00 is offline   Reply With Quote
Old 07-13-2012, 01:17 PM   #15
redstang98's Avatar
Do u know what the other thang is
Old 07-13-2012, 01:21 PM   #16
If you are talking about the line thats at the tip of your finger I want to say thats some sorta line for the AC....
Old 07-13-2012, 01:27 PM   #17
redstang98's Avatar
If u could give me a call it would be a great help
Old 07-13-2012, 01:35 PM   #18
I cant man...I'm deployed over seas right now and no cell phones...
why do you want to know what it is?
Old 07-13-2012, 01:36 PM   #19
redstang98's Avatar
It looks like it needs to be plug in somewhere
Old 07-13-2012, 01:45 PM   #20
wait a min...look on the coolant tank right below the coolant cap on the underside of the tank and see if it plugs in there....or like a hole or something like that would fit in.
Old 07-13-2012, 02:05 PM   #21
redstang98's Avatar
And thank you for everything u guys do and stay safe
Old 07-13-2012, 02:23 PM   #22
oh, well thanks and your welcome we def stay safe for sure I only have three more weeks.
Was that it?
Old 07-13-2012, 02:35 PM   #23
redstang98's Avatar
Yeah man
Old 07-13-2012, 02:38 PM   #24
sweet, im surpised it wasnt leaking coolant.
Old 07-13-2012, 03:04 PM   #25
redstang98's Avatar
Ok this is with the car running
Old 07-13-2012, 03:59 PM   #26
redstang98's Avatar
idle seems high and oil seems high?
Old 07-13-2012, 06:26 PM   #27
Region: Nevada
Your definitely high idle but your oil pressure looks ok. It may be slightly high because of your idle surging did you change out that PCV? That may solve your problem.
Old 07-13-2012, 06:34 PM   #28
redstang98's Avatar
Not yet waiting for a ride I don't want to mess my car up .when I drive it I have a lot of resistence on the pedal
Old 07-13-2012, 06:49 PM   #29
Region: Nevada
Hmm have you checked the throttle linkage at the tb and the pedal. just so you can make sure it's not hung up or anything? Resistance on the pedal tell me that it's a mechanical problem because the cable is just a cable that runs from the pedal through the firewall into the engine bay up to where it mounts on your stock intake pelenum. Pressing the gas pedal physically opens your throttle body so if it's difficult to press down the gas it's probably an issue with the tb or the linkage.
Old 07-13-2012, 06:52 PM   #30
redstang98's Avatar
What I meant its in the motor .when i press the gas the motor acts like it struggles to gain speed and sounds like crap .like its missing or something.
Old 07-13-2012, 06:58 PM   #31
Region: Nevada
Ahhh I got ya. That sounds like a vaccum issue wich if the PCV is clogged or partially clogged will cause and it can really make the car run like sh*t.
---------- Post added at 05:58 PM ---------- Previous post was at 05:56 PM ----------
Lemme know how swapping the PCV turns out. I'm pretty sure it's the problem.
Old 07-13-2012, 07:01 PM   #32
redstang98's Avatar
When I toke it out I cleaned it and can shake it . It will rattle a lot
Old 07-13-2012, 08:51 PM   #33
Region: Nevada
The fact that it was covered in oil or blow by means that it is no longer functioning properly and should be replaced. And your car is showing the symptoms of a bad PCV. Your lucky though a replacement for your year is only a few bucks whereas mine is 35$ ( mine is heated).
Old 07-13-2012, 09:23 PM   #34
redstang98's Avatar
I really want to thank you for all your help can I add u to my contacts . I live in the nc if ur ever in the area well go for a ride
Old 07-13-2012, 09:59 PM   #35
Region: Nevada
No problem man. I'm in NV so I'm pretty far away lol.
09:58 PM
