Stock specs - Mustang Evolution
Old 07-14-2012, 12:38 AM   #1
Kotty4643's Avatar
Stock specs
Does and one know the stock specs of a 96 mustang gt 4.6 v8????? Like gears and HP and what not
Kotty4643 is offline   Reply With Quote
Old 07-14-2012, 12:45 AM   #2
Rapinator126's Avatar
they were like 220hp back then i believe? and the gears look on your diff. case there will be a sticker that tells you. that is if they haven't been swapped out already.
Old 07-14-2012, 12:49 AM   #3
Spiney's Avatar
I have a 96 Ford Mustang brochure in front of me, bought it off EBay 4.6L V-8 stock HP 215 @ 4400 rpm. Torque 285 @ 3500 rpm. Don't have info on the gear ratio. Dave
Spiney is offline   Reply With Quote
Old 07-14-2012, 12:50 AM   #4
deadsp0t's Avatar
215 for 96 and 97. 98 got a bump to 225.
That's unimpressive
Old 07-14-2012, 12:50 AM   #5
deadsp0t's Avatar
Gears are likely 2.73 if a 5spd but could be 3.08 or 3.27 stock
That's unimpressive
Old 07-14-2012, 12:53 AM   #6
these guys got it for you. i dont really know much about the 96 and below non pi motors.
Old 07-14-2012, 12:54 AM   #7
deadsp0t's Avatar
You were close enough as you see though!
That's unimpressive
Old 07-14-2012, 07:14 AM   #8
9tee7pony's Avatar
I never realized that the power was that low. I guess I will have to change my shift points.
9tee7pony is offline   Reply With Quote
Old 07-14-2012, 10:44 AM   #9
1slosix's Avatar
Re: Stock specs
or do a PI swap
Old 07-15-2012, 10:51 AM   #10
Kotty4643's Avatar
It does not have stock gears I know that they were changed to 373
---------- Post added at 10:51 AM ---------- Previous post was at 10:49 AM ----------
And yes it's a 5 speed
Old 07-15-2012, 10:59 PM   #11
1slosix's Avatar
Re: Stock specs
pop the rear off the ground and find out for sure though. mark the driveshaft with a marker...now spin the rear tire one complete time. count how many times the mark makes a full rotation on the DS...that'll tell you what gearing you have. so between the 3 1/2 and 4 rotations will be 3.73s basically. good to know for sure right
Old 07-15-2012, 11:11 PM   #12
Kotty4643's Avatar
I will and ill let you know if u like
Old 07-15-2012, 11:14 PM   #13
1slosix's Avatar
Re: Stock specs
sounds good
Old 08-02-2012, 10:34 PM   #14
Kotty4643's Avatar
Re: Stock specs
yea they are 373 gears and i finnaly got the cluthc in a week ago and drove it for a week now the car is stuck in reverse and will not go back in neutral it only goes in reverse and another high gear my friend tried to force it out of reverse when i went to the bathroom now when its in reverse it looks like it is in 5th what do i do
10:49 PM
