Poping in front end - Mustang Evolution
Old 07-14-2012, 11:12 AM   #1
03 gtmustang's Avatar
Poping in front end
My stang has a popping noise when i turn my steering wheel .all i have to do is turn it a little and it pops .any advice would be helpful
03 gtmustang is offline   Reply With Quote
Old 07-14-2012, 11:30 AM   #2
bobsurvives's Avatar
Mine does the same...
bobsurvives is offline   Reply With Quote
Old 07-14-2012, 01:02 PM   #3
Re: Poping in front end
Where does it sound like its coming from? Like actually in the steering its self or like from the front end area?
The only thing I can tell you to do is have someone get under the car if they can and barely turn the wheel to see if they hear the noise. Check and make sure nothing is binding up in the steering and check your PS fluid and let us know what you find.
southernstang00 is offline   Reply With Quote
Old 07-14-2012, 01:06 PM   #4
I can feel it in the steering wheel. But it sounds like its coming from are around the wheels thank you for the info
Old 07-14-2012, 01:12 PM   #5
Jack the car up......make sure the steering wheel is locked. Go to each tire and try to move the tire sideways to see if the tie rod is bad. It also can be something wrong with the inner tie rod or the rack itself. Let me know what you find out
Old 07-17-2012, 07:36 AM   #6
TXstang125's Avatar
Mine dose that when I'm braking and then turn
TXstang125 is offline   Reply With Quote
06:54 PM
