a whining/grinding coming from what sounds like the transmission. what could it be? - Mustang Evolution
Old 07-15-2012, 01:37 PM   #1
ward.r's Avatar
I have a 2000 mustang gt 5 speed and out of no where 2day going down the highway im hearing a whining/grinding noise thought it was jus a semi or something but it would only happen when i was pressing the gas. I dont usually hear it til 3rd but gets louder the higher the gear no matter the speed you are going. What could be the problem?
ward.r is offline   Reply With Quote
Old 07-15-2012, 01:45 PM   #2
Re: a whining/grinding coming from what sounds like the transmission. what could it b
Can you get video of you driving it and the noise....might help out a little.
southernstang00 is offline   Reply With Quote
Old 07-15-2012, 02:14 PM   #3
ward.r's Avatar
I could try but the sound reminds me of a rubbing grinding sound and only really noticable n 3-5
---------- Post added at 03:14 PM ---------- Previous post was at 02:49 PM ----------
And the car shifts great no grinds no hard shifts jus noise and slight vibration
Old 07-15-2012, 06:41 PM   #4
1996mustang's Avatar
I had the same happen to my brothers mustang. Turned out to be the rear end i.e. ring and pinion gear. That was wat was making the loud noises on his i would check yours maybe u low on diff fluid or like his needed to be replaced and shimmed correctly
Old 07-15-2012, 10:31 PM   #5
ward.r's Avatar
A guy i was tlkn 2 says he thinks its my bearing in my higher gears bc its something in the trans.
Old 07-15-2012, 10:36 PM   #6
Turn your head to the side when it happens. If it gets louder in your rear facing ear it's probably rear end.
Old 07-21-2012, 07:43 PM   #7
ward.r's Avatar
My friend road in the bak seat and it wasn any louder in the bak than in the front we believe its a throw out bearing so i bought a new one and decided to change to the t-3650
08:52 PM
