Squeak when the clutch is disengaged - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1996-2004 Mustang GT
Closed Thread
Old 07-15-2012, 07:10 PM   #1
RedRocketGT's Avatar
RedRocketGT is unknown around these parts
Hi guys, I'm new to the forum. I have a 2001 gt with a BBK CAI and o/r magnaflow x pipes. I've noticed a slight squeaking noise when the clutch is completely disengaged, but it disappears the moment I touch the pedal. Any ideas?
RedRocketGT is offline
Old 07-15-2012, 07:20 PM   #2
lowflyn is unknown around these parts
Throw out bearing (tob). If it only does it with clutch out and is slight you might can get away with a clutch freeplay kit. I did a write up for a $3 home made one and it's on this site under write ups.
Worst case scenario you have to replace it. The part is only $15 but you have to pull the transmission to replace it
lowflyn is offline
Old 07-15-2012, 07:26 PM   #3
Thanks, my friend also said it was probably the bearing. Is it harmful to the transmission to drive it when its in this condition? Its my daily driver.
Old 07-15-2012, 07:31 PM   #4
Pete Jones
90mustangLX's Avatar
90mustangLX is unknown around these parts
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
Not the transmission itself but you run the risk of the bearing burning up/locking itself to the retainer and then you get no disengagement or engagement of the clutch.
If its not really noticeable you should be ok for a bit.
90 LX 5spd swap Stock 302 GT40P heads
BBK shorties and h-pipe
flowmaster 40's dumped, Jegs Big n Littles
BBK CAI, BBK SSI-R upper and lower
Professional Products 75mm TB,Electric Fan
MSD 8.5 90 degree plug wires
90mustangLX is offline
Old 07-15-2012, 07:34 PM   #5
Yeah its not too noticeable. Just a quiet squeak when its fully disengaged, but it goes away when the pedal is even lightly pressed.
Old 07-15-2012, 07:40 PM   #6
Basically your tob is slightly touching the clutch fingers and is spinning the entire time. It is only meant to spin when the clutch pedal is depressed. If it continues it will definitely wear prematurely and could score the input shaft which would require taking the transmission apart and replacing that shaft.
I would recommend fixing the problem sooner rather than later
lowflyn is offline
Old 07-15-2012, 07:48 PM   #7
Okay. I'll get on that, then. Thank you for your help!
Old 07-15-2012, 07:51 PM   #8
No problem. My fix takes five minutes once you get the car off the ground
lowflyn is offline
Old 07-16-2012, 10:26 AM   #9
1996mustang's Avatar
1996mustang is unknown around these parts
Dumb idea but could it not also be adjustment needed on the clutch cable. Not sayin it aint a tob but.... just thouggt id throw it out there
1996 Mustang GT, 17x9 front and 17x10.5 cobra r replica rims, 235/45 front 275/55 rear (for now)
o/r x-pipe flowmaster 40 series dump downs, cai/ram intake, 75mm c&l throttle body and plenum, pi heads and intake swap, msd wires, stock gears, untuned at the moment, no dyno numbers for now.
1996mustang is online now
Old 07-16-2012, 12:35 PM   #10
I think what he meant was that the cable needs to be adjusted to keep the tob off the pressure plate.
Old 07-16-2012, 08:20 PM   #11
Indeed i did lol i couldn't put words right lol
Closed Thread
06:39 PM
