vacuum questions. guess - Mustang Evolution
Old 07-16-2012, 02:31 PM   #1
redstang98's Avatar
Who knows
redstang98 is offline   Reply With Quote
Old 07-16-2012, 07:23 PM   #2
redstang98's Avatar
Guess no one knows what it is .
Old 07-16-2012, 07:38 PM   #3
Mile high JDF's Avatar
We kinda need more info to help you figure it out. Is it causing an issue or are you just curious? Also where is it located in the engine compartment?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 07-16-2012, 07:44 PM   #4
redstang98's Avatar
It comes out the back side of pliuem1/4 line
Old 07-16-2012, 07:45 PM   #5
redstang98's Avatar
Old 07-16-2012, 07:48 PM   #6
Is it causing any issues? Or do you just wanna know what it is? Usually I just google vacuum line diagrams if im curious about something.
Old 07-16-2012, 08:08 PM   #7
redstang98's Avatar
Issues . Pull PVC line and car shuts down fast
Old 07-16-2012, 08:11 PM   #8
Idle Air Control?
Old 07-16-2012, 08:24 PM   #9
redstang98's Avatar
Got me I don't know lol . Thats why
Old 07-16-2012, 08:28 PM   #10
1996mustang's Avatar
Evap purge flow sensor 100% sure of it
Old 07-16-2012, 08:35 PM   #11
redstang98's Avatar
Do u think it would make me lose horsepower?
---------- Post added at 08:35 PM ---------- Previous post was at 08:33 PM ----------
New plugs wires ,plugs ,PVC v ,oil sending unit ,oil change some vac lines . And still the same . Going to get comp. Test tomorrow . This car is draining me dry
Old 07-16-2012, 08:39 PM   #12
Buy a can of carb cleaner and spray around to see if rpm rise. It sounds like u have a vacuum leak and judging by the pic of the evap sensor u probably changed those vacuum lines by now.....hopefully
---------- Post added at 10:39 PM ---------- Previous post was at 10:38 PM ----------
Also these cars have a bad case breaking the plenum gaskets btw
Old 07-16-2012, 08:46 PM   #13
redstang98's Avatar
I have a can of sea foam too . I fills like its missing still half horsepower
Old 07-16-2012, 08:53 PM   #14
I have a dumb question check all the injector connectors being connectwd and very important there is a ground that goes to the valve cover which is a ground to the injectors.
Old 07-16-2012, 09:11 PM   #15
redstang98's Avatar
Where is it grounded to a rail or something ?
Old 07-17-2012, 02:06 AM   #16
Re: vacuum questions. guess
The top pic is the DPFE (differential pressure) which controls
Egr pressure. Google dpfe ford mustang for more info.
The second is is your oil pressure sensor. Make sure it's on.
---------- Post added at 01:03 AM ---------- Previous post was at 12:45 AM ----------
F
---------- Post added at 01:06 AM ---------- Previous post was at 01:03 AM ----------
Oops sorry. Looked at lower pic more closely. NOT oil pressure sensor. Btw, 1AA auto has explanation of egr and dpfe purpose and problems and how signalsfrom sensor go to computer and affect perf.
mmoorensandiego is offline   Reply With Quote
Old 07-17-2012, 06:24 AM   #17
F
My dear friend im sorry to say but you are dead wrong on the description of the two pics. The first is his evap purge sensor and the second is the pic of his plenum from the back showing the vacuums that goes from the plenum to the sensor which is located on the passenger side near the a/c accumulator. Dpfe is a silver box with 2 vacuums which go to the egr tube if this were it it would be on the driver side of the firewall ill includes pics in a sec
Old 07-17-2012, 07:36 AM   #18
Dpfe
Evap purge sensor
Old 07-17-2012, 08:24 AM   #19
redstang98's Avatar
Motor is a 98 the rest I guess comes from the factory stock 97 . Ive done all above but check fuel injectors what is the best way to check them at home
---------- Post added at 08:24 AM ---------- Previous post was at 08:21 AM ----------
After 4 different shops 700 dollar's later still no better almost ready to give up
Old 07-17-2012, 08:39 AM   #20
Check this ground that goes to the injectors. As to testing them turn the car on. Then unplug each one on by one taking notice in rpm drops if any also by any chance would u happen to have the mil code that are on ir car. Im sure ur check engine light is on so knowing the codes would help alot to figure out wats happening
Old 07-17-2012, 08:42 AM   #21
redstang98's Avatar
Im going in a bit to get yet another code check the shops didn't tell me what codes they were getting they gladly just got my money . Lol want to go postal
Old 07-17-2012, 08:51 AM   #22
Save your self money go to advance auto parts or autozone free code pulls but tell them to print it out or write them down. And dont listen to their suggestion sometimes lol they are parts sellers not ase techs
Old 07-17-2012, 08:57 AM   #23
redstang98's Avatar
Going in a bit . This is the only ground just one
Old 07-17-2012, 09:56 AM   #24
redstang98's Avatar
I can make that ground in different spot to ensure good connection right ?
Old 07-17-2012, 11:42 AM   #25
redstang98's Avatar
I wonder what this is between the batt and fuse box ? Looks bad
Old 07-17-2012, 12:14 PM   #26
redstang98's Avatar
Now that I think about this a minute. My ac did work good before the problem . Now not cold at all .huh this is crazy
Old 07-17-2012, 01:18 PM   #27
It looks like your fusible link or some other thing gimme some time ill get back to u on it soon when i get off work
Old 07-17-2012, 01:39 PM   #28
redstang98's Avatar
Code p0354 says coil d primary/secondary malfunction? At Advanced now
Old 07-17-2012, 01:52 PM   #29
Hmmm might be ur coil pack or it may be related to that connector u had unplugged
Old 07-17-2012, 02:08 PM   #30
redstang98's Avatar
I wish I had someone to help me that could look at it
---------- Post added at 02:08 PM ---------- Previous post was at 02:02 PM ----------
Could it be my comp.
Old 07-17-2012, 03:04 PM   #31
Doubt it honestly i was lookin into that for u about those connectors look like fusible links. btw did u connect that connector u found near the battery. im sure if u do it should fix the problem lmk what happens.
Old 07-18-2012, 07:45 AM   #32
redstang98's Avatar
Yeah I put it back but the same problem is there . This is pissing me off.
04:32 AM
