Head gasket thickness - Mustang Evolution
Old 07-17-2012, 04:12 PM   #1
t0t4lbl4ck0ut's Avatar
So I'm in the process of doing my build for my new motor and I'm possibly going all out with the bore and stroke. Bore of 3.700 and stroke of 3.750, but it will be running a kenne bell 2.6 running 25psi on track runs only. 15 on the street, with 44cc stage 3 ported trick flow heads and the lowest compression I could figure up with that bore and stroke was about 9.2 and that's with .073 head gaskets and 22cc dish pistons. I'm not familiar with gasket strength and thought that a thicker gasket would ruin the compression capabilities by have blow out capabilities. Someone shed some light on the subject cause I'd love to know and learn.
t0t4lbl4ck0ut is offline   Reply With Quote
Old 07-17-2012, 04:38 PM   #2
I sure don't know but...that's gonna be one badass car when you are done
96gt014.6 is offline   Reply With Quote
Old 07-17-2012, 09:45 PM   #3
Arron's racecar's Avatar
Region: Nevada
+1 can't wait to see the dyno sheet for that beast!
---------- Post added at 08:45 PM ---------- Previous post was at 08:36 PM ----------
To answer your question I dont know if thickness can be likened to quality of product. I do know that fel pro makes good quality gaskets. My friends all swear by them and I can say that they have stood up well to the 23 psi one is running on his STI. I wouldn't risk trying to look for a thicker gasket but again just my 2 cents.
2004 GT current mods : CAI, BBK Short throw shifter TB and UDPs, SCT x3/SF3 with BAMA Perfomance tunes Roush body kit, roush side skirt exhaust and paint.
Arron's racecar is offline   Reply With Quote
Old 07-18-2012, 02:29 AM   #4
Yea I did some research and they all say that I'm gonna have to run solid copper gaskets to withstand the pressure and possibly get o rings grooves put into the block and run that. I don't know if I'll be able to do all that to the block and run that high of boost. I'd have to run .093 gaskets to get to and below a 9:1 compression. Especially since it isn't going to be a race car it will be a toy pretty much.
Old 07-18-2012, 07:00 PM   #5
Region: Nevada
Well if the block can't handle it, maybe a compromise is in order, say trying to get down to about 20 psi instead. The car would still be a monster cuz those KB 2.6 are some mean blowers!
Old 07-18-2012, 07:45 PM   #6
It's not that the block can't handle it, it's jut the gasket that would be the weak point.
» Members Mustangs
Baby
Tommyboi
R1
Untamed5.0
Add your Mustang
06:26 AM
