supercharger - Mustang Evolution
Old 07-19-2012, 06:04 AM   #1
supercharger
Well I was looking around and I've decided im going with a Kenne Bell big bore 2.1 intercooled kit. Im going to run 60 Lbs injectors since my head are CNC ported and polished, 75mm TB and 90 mm air mass. Im not going to use the chip, but instead use the SCT Xcal 3 tuner. Any advice on this? Here it is:
'96-'04 Mustang 4.6 2V 2.1L Supercharger
southernstang00 is offline   Reply With Quote
Old 07-19-2012, 06:32 AM   #2
Lorraine's driver
ab_mach1's Avatar
I know this isn't advise, but KB kicks a$$!
Are you planning this for your GT or your new Cobra?
Instagram: @ab_mach1
Old 07-19-2012, 06:44 AM   #3
Rm360's Avatar
If your doing the install yourself you need to let kb know about the heads , you can get the tuner from them loaded with a start up tune , the reason I say start up tune is that I wasnt really happy with the tune so I went and had it retuned and dynoed
Old 07-19-2012, 07:15 AM   #4
WheelStander's Avatar
What's the price you get on this? I'm doing same thing.
Induction: Kenne Bell | wHp: 515 Tq: 503 | 1/4 Mile:11.09@123
WheelStander is offline   Reply With Quote
Old 07-19-2012, 07:24 AM   #5
Rm360's Avatar
The kit with inter cooler and boost a pump set up will run around $5,000
Old 07-19-2012, 07:49 AM   #6
Yes I agree man,and its for the gt.
---------- Post added at 08:49 AM ---------- Previous post was at 08:46 AM ----------
Yes, im doing the install myself and the tuner I have already. I was planning on getting it dyno tuned regardless by a local speed shop. You think I might have to send the tuner to them for the start up tune ?
Old 07-19-2012, 07:56 AM   #7
Lorraine's driver
ab_mach1's Avatar
Maybe you'll want to so you can keep your handheld married to your PCM...?
Old 07-19-2012, 08:01 AM   #8
Aw crap that's right I would have to take the tuner off to use the chip. I was going to use the chip that comes with the kit for the start up tune just to drive it on the trailer.
Old 07-19-2012, 08:15 AM   #9
Lorraine's driver
ab_mach1's Avatar
Maybe the chip that comes with it can be your new "stock" tune. Bare with me... You could flash back your stock tune. Install the KB and pop on the chip. Bring the tuner with you and see if they can use your tuner to flash the new dyno tune. The new dyno tune would saved on your tuner, along w/Ford stock tune. Then you could be married to the tuner and still be able to flash back and still use the chip that comes with the KB kit as well without losing the dyno tune.
Old 07-19-2012, 08:19 AM   #10
Ya know that's a good idea. I wonder if I will be able to drive it to the dyno place with the tuned kb chip ? Or should I trailer it?
Old 07-19-2012, 08:23 AM   #11
Lorraine's driver
ab_mach1's Avatar
Did RM360 mention the chip was setup with a basic tune from KB? If so, man I would hope it would be close enough to run enough to get you to the dyno.
Old 07-19-2012, 08:27 AM   #12
Naw he didn't I might just put it on a trailer its not far from them house.
Old 07-19-2012, 08:35 AM   #13
Rm360's Avatar
You can use the chip as the start up tune but I would still let them know about your heads as they flow more air than stock , kb 's tune is set up for stock heads. They might be able to write you a tune also and email it to you do you can still use your handheld I'm not sure about that tho!
Old 07-19-2012, 08:39 AM   #14
Oh ok gotcha well when I call I sure will let them know about my heads.
With stage three cams now, do you think you will hear the super charger at idle ?
Old 07-19-2012, 08:59 AM   #15
Rm360's Avatar
Just make sure you let them know about all your mods you want to try to get the tune as close as possible with the stage 3 cams you would still hear the sc faintly I'm actually surprised on how "quiet" the kb is compared to vortech and Paxton
Old 07-19-2012, 09:04 AM   #16
Oh I am, everything down to the CAI. It comes with 36 lbs injectors would you use them or go 60? Oh, ok well I want to hear it some but I'm sure you will hear it when you are WOT?
Old 07-19-2012, 09:17 AM   #17
Rapinator126's Avatar
thats bc a paxton and KB are 2 complete diff types of superchargers. you wont here a KB a iddle but will a full throttle. vs paxton which i loud at iddle and quiets down the more you get into boost
Old 07-19-2012, 09:33 AM   #18
Rm360's Avatar
There 90mm set up I believe comes with 42 lb injectors , according to kb's math the 42's can support up to 600 hp with a svt focus pump and boost a pump set up , I would probly go with the 60's tho better to have more than not enough
Old 07-19-2012, 10:45 AM   #19
Well in sticking to kb, I rather hear it on open throttle then hear it at idle. I was looking on the sure and it really doesn't anything about 42 injectors.
Old 07-19-2012, 10:50 AM   #20
Lorraine's driver
ab_mach1's Avatar
+1 on KB sound
Old 07-19-2012, 11:07 AM   #21
Yea buddy can't wait to get it
Old 07-19-2012, 11:12 AM   #22
Rm360's Avatar
The 42lb injectors come in the cobra, Mach 1 kit go to kb's web site and search for their article boost a pump vs svt focus pump it shows all the math formulas and talks about the 42 lb injectors
---------- Post added at 12:12 PM ---------- Previous post was at 12:07 PM ----------
Maybe it's called boost a pump theory explained its been a while since I read it
Old 07-19-2012, 11:17 AM   #23
My guy at Extreme Mustangs tells me categorically, use 60 on mine fwiw.
And this guy is a very successful owner of his shop.
Old 07-19-2012, 11:33 AM   #24
Rm360's Avatar
I agree I would just run the 60's!!
Old 07-19-2012, 11:34 AM   #25
Lorraine's driver
ab_mach1's Avatar
I've heard that going too big will just waste gas. I think that a lot of poo. Doesn't the ECU control how much goes through the injectors?
Old 07-19-2012, 11:43 AM   #26
Rm360's Avatar
For his set up with the heads and cams the 60's should be perfect The ECM controls the flow but can and will be adjusted in the tune to flow what you need as long as your fuel rails can handle the increase in fuel
Old 07-19-2012, 11:45 AM   #27
Yeah I'm just going to go 60 just in case.
Old 07-19-2012, 11:50 AM   #28
No need to change the fuel rails my guy says.
Old 07-19-2012, 11:53 AM   #29
I want to say the fuel rails come with the whole kit but I might get the bbk fuel rails.
Old 07-19-2012, 12:09 PM   #30
MachMan1017's Avatar
Excited to see the results when she's all done!
MachMan1017 is offline   Reply With Quote
Old 07-19-2012, 12:35 PM   #31
Lorraine's driver
ab_mach1's Avatar
Yeah, you'll need to start you a KB install thread so we can follow.
Old 07-19-2012, 12:36 PM   #32
Rm360's Avatar
I read something some time ago about the bbk fuel rails leaking where the fuel line connects to the rail , I also believe they fixed the problem , just make sure to ask before you buy, I want to say there was a thread on this forum about it but don't quote me on that!!
Old 07-19-2012, 12:39 PM   #33
Lorraine's driver
ab_mach1's Avatar
What am I talking about, keep here. Good from start to finish.
Old 07-19-2012, 01:07 PM   #34
Thanks for telling me that and I will keep that in mind.
Old 07-19-2012, 02:01 PM   #35
Rm360's Avatar
No problem I remember reading it just wanted you to be aware , nothing sucks more than doing all that work to have something fail, then have to wait 4 days to get a new part!!! LOL!!!
11:34 AM
