Flywheel Torque - Mustang Evolution
Old 02-27-2008, 09:10 AM   #1
1234's Avatar
Flywheel Torque
I bought a lightweight flywheel and a stage 2 clutch for my 03 gt what would be the torque for the flywheel?
Old 02-27-2008, 10:30 AM   #2
Herbstang's Avatar
Re: Flywheel Torque
What brand flywheel ?? Here's some SPEC torque ratings
SPEC Stage 1 Torque Capacity: 410
SPEC Stage 2 Torque Capacity: 520
SPEC Stage 3 Torque Capacity: 680
SPEC Stage 4 Torque Capacity: 680
SPEC Stage 5 Torque Capacity: 1100
Old 02-27-2008, 11:28 AM   #3
MonteCitan's Avatar
Re: Flywheel Torque
Did you mean the torque SPECS for torquing the flywheel on?
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 02-27-2008, 11:35 AM   #4
sledgehammer's Avatar
Send a message via Yahoo to sledgehammer
Re: Flywheel Torque
i think your right... he bought it and needs to put it on so it would make sense
94 v6 manual, 3.45s w/t-lock, cai, straight straight through dual exhaust, sct eliminator.
sledgehammer is offline   Reply With Quote
Old 02-27-2008, 01:06 PM   #5
Herbstang's Avatar
Re: Flywheel Torque
That was the same thing I thought !! But the question was very fague
Old 02-27-2008, 09:41 PM   #6
1234's Avatar
Re: Flywheel Torque
Sorry for being vague. I meant the torque specs for installing a Fidenza aluminum flywheel?
Old 02-28-2008, 06:04 AM   #7
Herbstang's Avatar
Re: Flywheel Torque
Here's some info
Camshafts caps to head 71-106 in/lbs
Camshaft sprocket bolts 82-92 ft/lbs
Cylinder head bolts SOHC (two valve GT and Bullitt)
--Step 1 28-31ft/lbs
--Step 2 Tighten additional 90 degrees
--Step 3 Loosen one full turn
--Step 4 28-31ft/lbs
--Step 5 Tighten additional 90 degrees
--Step 6 Tighten additional 90 degrees
Cylinder head bolts DOHC (four valve Cobra, and Mach One)
--Step 3 Tighten additional 90 degrees
Drive belt idler and tensioner bolts 15-22 ft/lbs
Engine compartment brace bolts 15-22 ft/lbs
Engine mount to engine block bolts/studs 25-33 ft/lbs
Engine mount stud to crossmember nuts 95-126 ft/lbs
Exhaust manifold to cylinder head bolts 14-16 ft/lbs
Flywheel moutning bolts 59-64 ft/lbs
Ignition coil brackets to front cover 12-22 ft/lbs
Intake and side plates assembly to cylinder head
--Step 1 15-22 ft/lbs
Intake manifold to cylinder head bolts
SOHC (two valve GT and bullitt) 15-22 ft/lbs
DOHC (four valve Cobra and Mach One)
Upper plenum to intake 71-106 in/lbs
Intake to lower side plates 71-106 in/lbs
--Step 1 15 ft/lbs
Oil cooler to filter adapter insert
-1996 59-74 ft/lbs
-1997-later 41-53 ft/lbs
Oil filter adapter bolts 15-22 ft/lbs
Oil pan to engine block bolts
-1996 15-22 ft/lbs
-1997-later
--Step 1 15 ft/lbs
--Step 2 Tighten additional 60 degrees
Oil pick up tube to main bearing cap nut 15-22 ft/lbs
Oil pick up tube to oil pump bolts 71-106 in/lbs
Oil pump to engine block mounting bolts 71-106 in/lbs
Thermostat housing bolts 15-22 ft/lbs
Timing chain cover bolts 15-22 ft/lbs
Timing chain tensioners and guides 15-22 ft/lbs
Valve cover bolts 71-106 in/lbs
Vibration dampner to crankshaft bolt
-1996 114-121 ft/lbs
-1997-later
--Step 1 66 ft/lbs
--Step 2 Loosen one full turn
--Step 3 36 ft/lbs
--Step 4 Tighten additional 90 degrees
Water pump mounting bolts 15-22 ft/lbs
Water pump pulley mounting bolts 15-22 ft/lbs
Wheel lug nuts 85-105 ft/lbs
Old 02-28-2008, 06:49 AM   #8
Re: Flywheel Torque
you best check with the flywheel manuf. to double check they may have different specs if the material (aluminum vs stock) differs.
Old 02-28-2008, 07:11 AM   #9
Herbstang's Avatar
Re: Flywheel Torque
FAQ
Old 02-28-2008, 10:06 AM   #10
1234's Avatar
Re: Flywheel Torque
you guys rock thanks for the help.
flywheel bolts 1996v6stang Pre-2005 V6 Mustang 2 07-12-2010 11:47 AM
Looking for stock V6 flywheel Foxone Pre-2005 V6 Mustang 0 04-07-2010 05:25 PM
Help! Flywheel question. Dsimps 1979-1995 Mustang GT 3 03-10-2008 09:36 PM
looking for a flywheel cjd10 The Bar 2 03-20-2005 04:19 PM
Flywheel questons Tbird232ci Pre-2005 V6 Mustang 3 05-09-2004 09:40 AM
01:55 PM
