Finishing up my Billet Interior - Mustang Evolution
Old 07-20-2012, 07:15 AM   #1
WheelStander's Avatar
Couple more parts for my interior.
I'll post up some pics later today.
Any special trick getting the cruise buttons off?
Induction: Kenne Bell | wHp: 515 Tq: 503 | 1/4 Mile:11.09@123
WheelStander is offline   Reply With Quote
Old 07-20-2012, 07:18 AM   #2
Rm360's Avatar
A very small thin screwdriver is all you need they will pop right out!!!
Old 07-20-2012, 07:26 AM   #3
Thanks!
Old 07-20-2012, 07:33 AM   #4
Lorraine's driver
ab_mach1's Avatar
Right on! It's gonna look good
Instagram: @ab_mach1
Old 07-20-2012, 09:01 AM   #5
It's never easy I pop the new billet buttons on and my cruise didn't work so I took the buttons off and the cruise still doesn't work Musta blew a fuse somehow.
Anyone know where that's located?
Old 07-20-2012, 10:07 AM   #6
Re: Finishing up my Billet Interior
My buddy adjusted my clutch the other day, I think that is the problem:
"today while driving I kept hitting the button to activate and nothing, dead as a doornail, than I thought I just put in a brand new clutch cable and clutch kit, so I thought maybe theirs a sensor on the clutch pedal?!?!?!?! SO I put my foot under the clutch pedal while driving and pulled back 1/8" back towards me while driving and sure enough when I hit the on plus set accelerator button it WORKED LIKE A CHARM, So im under the impression I need to move my clutch pedal back 1/8" towards me so the sensor has contact or I need to adjust my clutch cable a slight bit more???? NEED TO CALL MY INSTALL GUY TO SEE WHAT HE SAYS, it seems like a easy fix since its working with slight back pressure on the pedal which in theory is pushing the top of the clutch pedal towards the engine bay which means their has to be a sensor somewhere up their."
Gonna try that...
That worked, it was the clutch.
Old 07-20-2012, 03:53 PM   #7
Stereo is next.
ID:	60025   Click image for larger version
Old 07-20-2012, 04:07 PM   #8
Lorraine's driver
ab_mach1's Avatar
Originally Posted by WheelStander
Stereo is next.
Looks awesome! And your cruise works now too?
Old 07-20-2012, 05:00 PM   #9
Thanks Azure. Yeah the cruise is working, had to adjust the clutch cable under the dash a little bit.
Old 07-25-2012, 07:21 PM   #10
I picked up a lighter delete, power plug, coin delete and fog light button.
How exactly do I get the fog lamp button off?
Old 07-25-2012, 07:22 PM   #11
Lorraine's driver
ab_mach1's Avatar
It's not the whole switch?
Old 07-25-2012, 07:34 PM   #12
Just the button.
Old 07-25-2012, 07:42 PM   #13
Lorraine's driver
ab_mach1's Avatar
Just the button.
Hmm, maybe you can pop out the bezel around the shifter and get to the switch. Maybe there is some way to release the button from the switch.
Old 07-25-2012, 07:44 PM   #14
Ok thanks. I'll try popping up the bezel.
Old 07-25-2012, 08:23 PM   #15
Lorraine's driver
ab_mach1's Avatar
Does your new fog light button look like the in the pic below on the left?
Old 07-25-2012, 08:25 PM   #16
Lorraine's driver
ab_mach1's Avatar
Seems like it would pop off like the ones on your door did, if like the ones in the pic.
Old 07-25-2012, 08:28 PM   #17
Yeah it looks like that.
I didn't do the ones on the door so I'm not sure exactly how.
Thanks.
Old 07-25-2012, 08:35 PM   #18
Lorraine's driver
ab_mach1's Avatar
I went out and looked at mine, but it's different. Must have changed them by 2004.
Old 07-26-2012, 06:16 AM   #19
Lorraine's driver
ab_mach1's Avatar
Here are 2004 buttons...
Old 07-26-2012, 07:36 AM   #20
I can't get this thing to pop out. UPR says 10 minute installation but doesn't provide instructions I've got no clue at this point...
And what should I do with that plug it's attached to the trim ring on the power supply? Cut it off remove it ?
You need a lighter delete like mine-thanks for the info so far.
ID:	60945   Click image for larger version
Old 07-26-2012, 08:07 AM   #21
Lorraine's driver
ab_mach1's Avatar
It looks like the best way to pop the button off would be with a little screw driver between the button and the edge of the button housing. Try it at or near the middle. Try to pry the screw driver such that the button moves away from the edge some, then pry up to where it would pop out. Hopefully you can see how it's going to go as you start to pry. Check out the arrow in the pic.
I'd like to get a lighter delete or cap so I can pop it off and plug my phone in.
Old 07-26-2012, 08:10 AM   #22
Lorraine's driver
ab_mach1's Avatar
Little screwdriver like this myaa
Old 07-26-2012, 10:49 AM   #23
I can get the side closest to driver to pop up using that method but pass side just wont pop up...weird.
Edit: I pulled the whole assembly.
Old 07-26-2012, 06:49 PM   #24
Not sure if I do anything else...
ID:	61009   Click image for larger version
Old 07-26-2012, 07:10 PM   #25
Lorraine's driver
ab_mach1's Avatar
Looks good man! So how did that somna B come off?
Old 07-26-2012, 07:26 PM   #26
I had to take the Assembly out and pry the button out with two screwdrivers it was a pain in the butt I'm surprised I didn't break the switch.
Old 07-26-2012, 07:35 PM   #27
Lorraine's driver
ab_mach1's Avatar
Well I'm glad it turned out cause it looks good. Did the tilt wheel handle just unscrew off?
Old 07-26-2012, 07:46 PM   #28
Thanks.
Had to use a mini wrench, came off really hard though.
Thanks for the help.
Old 07-26-2012, 07:48 PM   #29
Lorraine's driver
ab_mach1's Avatar
No prob!
12:12 AM
