TOB replacement - Mustang Evolution
Old 07-20-2012, 10:23 AM   #1
runvsofthisbull's Avatar
TOB replacement
How difficult is it to replace the throw out bearing on my T-45. The sqeaking noise is driving me nuts. I'm new to the 5 speed world, but have access to a lift.. I'm assuming that I disconnect my negative battery, unbolt the driveshaft, crossmember, disconnect all electrical connections,and then just unbolt the ...x... Number of bolts from the tranny to the block, then swap it out? I looked it up on my Haynes manual but just want to know if there is anything very challenging or some specific/unique tools I will need other than air ratchets/torque wrenches. Ohh do I also have to remove the entire shifter? Thanks guys new to this and can't standnthe squeaking noise it's making, but don't wan
t to pay someone if I can do it myself with a friend. Ohh and replacement part should I just buy it from ford or is there a better one to buy. Any way to keep it from squeaking in the future?
2002 True Blue V6 to GT Vert
16.1@86 as an auto 3.8
Old 07-20-2012, 10:40 AM   #2
Silversky545's Avatar
Not too bad just helped a friend w a 96 w a pi swap.... should be about the same... I'd replace clutch an fly wheel while your at it though
Silversky545 is offline   Reply With Quote
Old 07-20-2012, 04:56 PM   #3
jhagan1980's Avatar
I replaced one with a centerforce TOB. I took out, replaced, and reinstalled my trans by myself without a lift. That was the first time I did anything of that nature and it wasn't that hard at all. I changed out clutch, TOB, pilot bearing, flywheel, clutch fork, clutch cable, and quadrant while I was in there.
jhagan1980 is offline   Reply With Quote
04:35 PM
