Help Cleaning Up my New GT - Mustang Evolution
Old 07-20-2012, 08:32 PM   #1
FordAddict's Avatar
Some of you have seen my other thread on my new 2003 GT Centennial 5 Speed. These are things I need to do...
New Tires
New Brakes
Repaint Calipers
*Remove E Brake Boot
*Install New A/C Vent
New Window Tint
Fix Sunroof Squeak
*Re-Attach Shaker Scoop Weather Stripping
Replace Tie Rod End
*Possibly New Throttle Cable
*Plug in MIL Eliminators
How do I fix the stared items?
Here's some pics
FordAddict is offline   Reply With Quote
Old 11-30-2012, 07:11 AM   #2
WheelStander's Avatar
I want your park brake boot.
WheelStander is offline   Reply With Quote
Old 11-30-2012, 02:23 PM   #3
JetLife 01GT's Avatar
New Tires
New Brakes
Repaint Calipers
New Window Tint
Fix Sunroof Squeak
Replace Tie Rod End
Here's some pics
Nice stang! Why do you want to remove the e brake boot? I tried to remove mine to clean it once but when it didn't come right off and I gave up pretty quickly lol. As for AC vent, just pop em on and off. The two in the center you have to remove the plastic trim around it as well. A flat head screw driver is usually best to use but take it slow so you don't damage the plastic. Mil eliminators are easy. Unplug the rear o2 sensors, then plug one end of the mil to the o2 sensor and the other side plug in where the o2 sensor was plugged in. The rear o2 sensors are located on the mid pipe near where they connect to ur catback. I'm sure someone else will chime in about throttle cable and weatherstripping
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 11-30-2012, 03:53 PM   #4
DerekJohnScott's Avatar
Try oiling the sunroof rails.
DerekJohnScott is offline   Reply With Quote
Old 12-05-2012, 08:31 AM   #5
FordAddict's Avatar
No need to respond to this thread. check my recent thread
« IRS Swap | Keeper! »
» Members Mustangs
LOU'CY
boink
skully
skully
Add your Mustang
08:25 AM
