Need help - Mustang Evolution
Old 07-22-2012, 12:06 PM   #1
Nelson4's Avatar
Need help
I have a 02 gt, it's been making a winding noise and I first I thought it might be the pulleys or belt so I changed them but now it sounds like the noise is coming from under my car, and ideas? Thanks.
Nelson4 is offline   Reply With Quote
Old 07-22-2012, 02:01 PM   #2
Nelson4's Avatar
Bump
Old 07-22-2012, 02:05 PM   #3
It's not me, it's you.
primer2tone's Avatar
Does the sound get louder when you accelerate? Have you checked all your fluid levels?
Old 07-22-2012, 02:25 PM   #4
Nelson4's Avatar
It does get louder ten quits, all fluids seem good.
Old 07-22-2012, 03:56 PM   #5
BigB227's Avatar
Well start by checking everything out, jack the car up and spin the wheels to see if the bearings make any noise and if not listen by the driveshaft to see if you hear and noise from the U joints and it could possibly be a transmission noise as well
BigB227 is offline   Reply With Quote
Old 07-22-2012, 04:07 PM   #6
Nelson4's Avatar
I'll check that out, thanks.
Old 07-22-2012, 04:27 PM   #7
Does it do it at idle or when you're driving?
Old 07-22-2012, 05:24 PM   #8
Nelson4's Avatar
Both
Old 07-22-2012, 08:28 PM   #9
ward.r's Avatar
Ok my car is kinda the same way mine is bearings n the drivetrain do u feel vibrations n ur shift knob or does it get louder each gear no matter the speed ur going?
ward.r is offline   Reply With Quote
Old 07-23-2012, 08:09 AM   #10
Nelson4's Avatar
My shifter doesn't really vibrate and it gets a Little louder no matter my gear or speed.
Old 07-23-2012, 12:39 PM   #11
ward.r's Avatar
Ok well look the things i can think of would b your rear end so u need to listen and see if you can tell if its around the transmission or the back of the car if its the back its in your rear end otherwise its a transmission bearing
Old 07-23-2012, 12:56 PM   #12
Re: Need help
if its a 5 speed does it go away or change if you push the clutch in when its doing it etc?
Old 07-23-2012, 10:48 PM   #13
Nelson4's Avatar
No it doesnt go away when I push clutch in, it's mainly making the noise when I'm at idle but I changed my belt and idler pulley thinking that would fix it but it doesn't sound like its coming from under hood.
Old 07-23-2012, 10:55 PM   #14
Lorraine's driver
ab_mach1's Avatar
If your sitting idling, does it get worse when you move the steering wheel to the left or right?
Instagram: @ab_mach1
Old 07-24-2012, 07:23 AM   #15
Nelson4's Avatar
Naw has the same pitch no matter what I'll do, when I start driving it eventually goes away.
Old 07-24-2012, 07:53 AM   #16
Lorraine's driver
ab_mach1's Avatar
Does it sound like metal on metal? Is it very loud or just noticeable?
Old 07-24-2012, 08:08 AM   #17
Nelson4's Avatar
Kinda sounds like that an it's just loud enough to notice it, it's not extremely loud but u can hear it
Old 07-24-2012, 08:23 AM   #18
Lorraine's driver
ab_mach1's Avatar
So, you mainly hear it at idle, not driving? If yes while driving, does it get louder or more noticeable at a certain RPM?
And, it goes away when the car warms up? Like 2 to 5 minutes?
Old 07-24-2012, 08:57 AM   #19
Nelson4's Avatar
Yeh mainly while it's at idle, it gets a little louder when I drive but not much more.. It goes away I'm guessing after it warms up but if I stop at a red light or so you can hear it again sometimes not everytime tho it's strange.
Old 07-24-2012, 09:35 AM   #20
Lorraine's driver
ab_mach1's Avatar
Man, that's a tough one. Sure seems like it could be one of the accessories. Like maybe the bearings on your alternator. Maybe the power steering pump. If you can get a long screw driver to touch against these carefully, while idling, you might be able to amplify the noise and determine what is generating it. It may need to be long enough that you can get you ear on the other end of the screwdriver if it's not loud or vibrate enough.
Old 07-24-2012, 10:13 AM   #21
Nelson4's Avatar
I'll give that a check and hopefully I can figure it out, thanks for all the advice.
Old 07-24-2012, 05:28 PM   #22
LAS97GT's Avatar
What type of exhaust setup you have? Loose mid pipes expand and contract under heat. If its a close fit, it will make weird sounds. My 2 cents.
---Las97GT
Old 07-24-2012, 05:31 PM   #23
Nelson4's Avatar
It's just stock exhaust but its also a ten year car, I'm planning on changing the exhaust soon.
Old 07-25-2012, 11:47 AM   #24
infamous281's Avatar
Throw Out Bearing
01:27 PM
