Broken Clutch Cable - Mustang Evolution
Old 07-23-2012, 10:42 PM   #1
Balltaatic01's Avatar
Broken Clutch Cable
I was out driving around tonight and I was shifting from 3rd to 4th and my cable snapped and my pedal just flopped. Is there a certain brand I should get to replace it? Is it difficult to replace? Any other advice for this situation?
Balltaatic01 is offline   Reply With Quote
Old 07-24-2012, 12:38 AM   #2
t0t4lbl4ck0ut's Avatar
Pretty easy. I'd suggest getting a oem replacement or a brand that uses oem cables like maximum motorsports
t0t4lbl4ck0ut is offline   Reply With Quote
Old 07-24-2012, 09:39 AM   #3
Can the OEM cable be used with everything else being stock or do I need to buy additional parts?
Old 07-24-2012, 10:17 AM   #4
Oem will work with anything
Old 07-24-2012, 10:25 AM   #5
McNassty's Avatar
OEM is stock
McNassty is offline   Reply With Quote
Old 07-24-2012, 11:23 AM   #6
Re: Broken Clutch Cable
OEM, aftermarkets are known to stretch out quick, just stay OEM.
Old 07-24-2012, 05:21 PM   #7
LAS97GT's Avatar
I bought a Steeda kit. However, if the input shaft is not lubed the clutch gets stiff, hence stretched cable.
---Las97GT
Old 07-24-2012, 06:00 PM   #8
Exactly. No need to buy an adjustable cable when you can buy a firewall adjuster and adjust it that way.
01:54 AM
