mach 1 motor - Mustang Evolution
Old 07-24-2012, 11:10 PM   #1
meano1's Avatar
mach 1 motor
Was wondering if a 04 mach 1 motor will bolt up in my 98 gt?
1998 Mustang Gt, MSD coils, Ford Racing lowering springs, KYB shocks, caster camber plates, Flow Tech exhaust, K&N CAI, auto trans with shift kit, Jet Performance module, full length sub frame connectors, Redline Tuning hood struts. Oh yea, forgot to mention the Plasti Dip stripes.
meano1 is offline   Reply With Quote
Old 07-24-2012, 11:13 PM   #2
infamous281's Avatar
Re: mach 1 motor
It will fit but your going to need
Wire harness
Transmission
Flywheel
Clutch
All the parts off the mach1
And some custom parts
Old 07-25-2012, 09:26 AM   #3
Lorraine's driver
ab_mach1's Avatar
95v686gt is working on a Mark 8 DOHV swap in his 97 GT. I think he's looking for an intake. He is good at obtaining used parts on the cheap. I'm sure he can provide some insight.
Nomad32v just did a swap of a Mark 8 DOHV in his 02 GT. He might be able to help with info on a 98 swap too.
The reason for the Mark 8 engine is that you can get these motors cheaper than a Mach1 engine. Probably easier to find I'm guessing too. Search through some of their threads for info. Good luck!
Instagram: @ab_mach1
Old 07-25-2012, 09:39 AM   #4
Yeah cheaper but The Mach1 has Forged Internals and better Heads/Cams
Old 07-25-2012, 09:46 AM   #5
Lorraine's driver
ab_mach1's Avatar
I didn't know the Mach engines had forged internals.
Nomad32v did some work on his Mark 8 engine before he dropped it in. He plans to slap a blower on it down the road. I think he was looking for teksid block. The Mach's are not teksid. I can't remember where they are made. But, I think the teksid block is stronger and will handle FI better.
Old 07-25-2012, 10:48 AM   #6
DaBluedude's Avatar
The mach 1 engines are a WAP block (windsor aluminum plant) and are NOT forged. (Sorry azure) the rods are definitely the weak point. The stock power limit is about 450hp.
2003 Mach 1
Old 07-25-2012, 11:04 AM   #7
Lorraine's driver
ab_mach1's Avatar
Thanks! I knew there was a reason Nomad32v was not using the Mach1 block.
Old 07-25-2012, 11:32 AM   #8
DaBluedude's Avatar
The wap block is good for about 750 lb ft of tq.
2003 Mach 1
Old 07-25-2012, 11:33 AM   #9
taylor98gt's Avatar
Azure do you know.anything about the Lincoln town car 4.6? I found one for 200 with a tranny, I figured that may be a good build start
taylor98gt is offline   Reply With Quote
Old 07-25-2012, 11:44 AM   #10
Lorraine's driver
ab_mach1's Avatar
No sorry, I didn't even know the Mark 8 cars had DOHV 4,6's until I got on here and started talking to Nomad32v, LOL
Old 07-25-2012, 11:59 AM   #11
DaBluedude's Avatar
There the same as the 4.6 2v in the gt I'm pretty sure.
2003 Mach 1
Old 07-25-2012, 12:09 PM   #12
ColeJohnson's Avatar
Re: mach 1 motor
+1 From what I understand they are the same.
2016 Comp Orange GT (current)
Old 07-25-2012, 12:47 PM   #13
taylor98gt's Avatar
Okay thanks guys I think its a good deal 200 for compleate motor and transmission. I'll prolly pass it up for a better block though lol
Old 07-25-2012, 01:02 PM   #14
I was thinking about Terminator Blocks.. Sorry
Old 07-25-2012, 01:04 PM   #15
Re: mach 1 motor
mach 1's with manual trans have a forged crank the auto does not. Neither have forged rods/piston.
Old 07-25-2012, 02:10 PM   #16
Lorraine's driver
ab_mach1's Avatar
Re: mach 1 motor
Thanks Spector, makes you wonder why the crank w/manual tranny. Do you think because of the herky-jerky TR-3650 trannys?
Old 07-25-2012, 06:09 PM   #17
32vNomad's Avatar
Re: mach 1 motor
4v are made to rev,and manuals spin higher longer naturally then there auto brethren. the upper valve train is made to spin 8k+. Gt's have the same 3650 and can spin up abit. The valve train is also made to spin as the rockers and lash adjusters are the same. PI GT's also have beehive springs. Ford though mass produced the GT, in comparison the Cobra and Mach are low build numbers. Bottom line COST. Just as in the 97-98 triton 5.4 came with a forged units. But cost reared its ugly head.
The stock bottom end is stout to handle 400+ (have seen 500 2yrs still running) the issue people have is tunes. Tunes are the culprit most of the time in engine failure. You can burn up an engine because the traction coming on during WOT on a FI engine, because the ECM retards timing and cuts fuel. There are many vehicles that have powder forged rods. One being the LSx engine they to have powder cast rods and enuthitic pistons.
32vNomad is offline   Reply With Quote
Old 07-25-2012, 07:20 PM   #18
Lorraine's driver
ab_mach1's Avatar
Thanks Nomad!
32vNomad not Nomad32v dammit, sorry bro!
Old 08-05-2012, 02:48 PM   #19
32vNomad's Avatar
Re: mach 1 motor
Thanks Nomad!
Its all good bro in other circles Im known as NomadGT
06:07 PM
