1998 GT Check Engine Light - Mustang Evolution
Old 07-25-2012, 10:55 PM   #1
98RedGT's Avatar
Car runs fine then will randomly idle and run a little rough and the check engine light comes on. Will eventually go off and run fine then after a while do the same thing? Any idea?
ROOM FOR IMPROVEMENT
98RedGT is offline   Reply With Quote
Old 07-26-2012, 12:23 AM   #2
Lorraine's driver
ab_mach1's Avatar
I looked up that code and it's probably the O2 sensors, or one of them. Was there any other codes with P1151?
Instagram: @ab_mach1
Old 07-26-2012, 12:27 AM   #3
maldog's Avatar
Region: Nevada
Re: 1998 GT Check Engine Light
Have u done anything recently to the engine? Cleaned ur air filter? Do u have a CAI? If u over oil ur air filter it will do all sorts of strange things. The oil will also get on the MAF sensor and screw with things. I know because it's happened on my GT. I cleaned the MAF sensor and the air filter on my CAI, cleared all my codes and she's back to normal.
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 07-26-2012, 01:12 AM   #4
infamous281's Avatar
Most likely a Bad Sensor.. IAC or TPS
Old 07-26-2012, 01:26 AM   #5
98RedGT's Avatar
Nothing recently, and yes I have a JLT CAI. Would the MIL eliminators fix it?
Old 07-26-2012, 04:37 AM   #6
No, they work on the rear o2 sensor and this code is from the front. Check your fuse box and see if a fuse wasnt blown. If not then just get you too new sensors. Im sure they havent ever been changed before so get two new ones from the front, or upstream sensors. Look at them and make sure they are connected correctly and not burnt agaisnt the exhaust.
southernstang00 is offline   Reply With Quote
check engine
06:32 AM
