need ideas... - Mustang Evolution
Old 07-26-2012, 11:29 AM   #1
ward.r's Avatar
need ideas...
Ok well i have a 2000 gt wit the 01 HO in it. I just put a 7.5 posi in it with 3.23s what would b a good gear set to use since im doing a 04 cobra swap with a kenne bell procharger?
ward.r is offline   Reply With Quote
Old 07-26-2012, 11:35 AM   #2
Mile high JDF's Avatar
Um well you would need an 8.8 axle swap first. That 7.5 would blow up the minute you put sticky tires on. Otherwise 3.73s or 4.10s. Also go look at ColeJohnsons sig, he has a good link about gears in it.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 07-26-2012, 11:37 AM   #3
vinnygt's Avatar
Kenne bell procharger?? Maybe u meant supercharger. And in response to your question- that depends what tranny your going to be using. Automatic or stick?
---------- Post added at 12:37 PM ---------- Previous post was at 12:37 PM ----------
Glad u caught that too... Lol
vinnygt is offline   Reply With Quote
Old 07-26-2012, 11:46 AM   #4
ward.r's Avatar
Stick
Old 07-26-2012, 12:07 PM   #5
Re: need ideas...
If you have a 2000 GT why did you put a 7.5" in? They come with an 8.8" with 3.27's from the factory.
Just confused with that one...
I would say a 3.73 or 3.90 ratio would be best for a high hp profile like that. 4.10's+ always provide you with "more" but you may want that 1st or even 2nd gear at times.
Old 07-26-2012, 03:03 PM   #6
infamous281's Avatar
Wow
Old 07-27-2012, 07:19 AM   #7
Re: need ideas...
Im a little confuse on why you put a smaller rear end in a car that has a big one to start with. Anyways, far as gears I would say 373 with a stick supercharged car. So where you can have some what of a first and 2nd when you need it. Im going with 373 cuz its a all around gear.
southernstang00 is offline   Reply With Quote
Old 07-27-2012, 08:05 PM   #8
ward.r's Avatar
My 8.8 went out and blew the spider gears and the only thing i cld find was the 04 7.5 posi
Old 07-27-2012, 11:30 PM   #9
Re: need ideas...
2004 Gt's still have the 8.8 rear end.
Old 07-27-2012, 11:49 PM   #10
Stockish302's Avatar
So you put a v6 rear end? You can find a 8.8 for $150 in any junkyard. Any ways go with 3.73s great for a blown car 4.10s are good but if you daily drive your car the 3.73s are perfect
BBK cai, 96 tbird maf housing, BBK 70mm TB, TFS intake manifold, BBK shortys, bassani off road X pipe, Flowmasters with turndowns
If any one is willing to donate parts to the Make Joe's Mustang Faster that Corvettes Foundation, donations will be gladly appreciated
Stockish302 is offline   Reply With Quote
Old 07-29-2012, 11:31 AM   #11
ward.r's Avatar
The place i got it said all they had was that and was suppose 2 b out of a 04 gt because the tranny i put n was a t3650 out of the same 04
Old 07-29-2012, 04:11 PM   #12
Re: need ideas...
Idk.. If its a v6 Rearend then its gnna blow fast..
Maybe you dont know what your talking about or the shop was talkng about
It should be a 8.8 with a Ford Trac-Lok
do a burnout and see if you leave 2 tire marks on each side of the car ..
Old 07-29-2012, 08:30 PM   #13
02 360R's Avatar
Re: need ideas...
not trying to change the subject, but can anyone give a suggestion for wheels and suspension. i just got a stang about a week ago and discovered the suspension is done and the wheels are not the best either. i want to go staggered wheels and a suspension that will lower the car some to give it an aggressive stance. any ideas out there?
02 360R is offline   Reply With Quote
Old 07-29-2012, 08:45 PM   #14
Hop onto AmericanMuscle.com they have a great selection of everything for our cars. I personally like H&R springs, I have a set of their race springs on my car now. The best way to get your questions answered as best as possible would be to start your own thread.
Old 07-29-2012, 09:16 PM   #15
02 360R's Avatar
Re: need ideas...
thanks
Old 07-29-2012, 09:19 PM   #16
thanks
No problem
11:03 AM
