4.10 or 4.56 gears - Mustang Evolution
Old 07-26-2012, 02:28 PM   #1
crazymonkey3533's Avatar
Question 4.10 or 4.56 gears
Anyone have recommendations on which set of gears I should get? I am not worried about gas mileage, I just want power. Also, is there anything else i should get to go with the gears? Thanks.
crazymonkey3533 is offline   Reply With Quote
Old 07-26-2012, 03:01 PM   #2
infamous281's Avatar
373s
Old 07-26-2012, 03:29 PM   #3
BigB227's Avatar
Well if it's down to those gears I think the 4.56s would be too much gear, you'd be spinning tires everywhere an might have the car jump from underneath you so I'd say 4.10s
---------- Post added at 05:29 PM ---------- Previous post was at 05:29 PM ----------
Maybe even 4.36s?
BigB227 is offline   Reply With Quote
Old 07-26-2012, 03:39 PM   #4
Mustang936's Avatar
I would say 4:10s the 4:56 is probably too much gear
Mustang936 is offline   Reply With Quote
Old 07-26-2012, 07:47 PM   #5
CrookedHalos's Avatar
A slab of concrete in the boot can fix traction haha
CrookedHalos is offline   Reply With Quote
Old 07-26-2012, 09:10 PM   #6
It depends on what the car is used for... If it is just a weekend car and a car taken to the track all the time then go 4.56... Otherwise go 4.10s
Old 07-26-2012, 09:13 PM   #7
The Blue Dragon
GrabberBlue5.0's Avatar
Re: 4.10 or 4.56 gears
^ agreed. 4.56 is way too much and would render first gear absolutely useless, it would be more like you were driving a 4 speed
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 07-27-2012, 04:35 AM   #8
t0t4lbl4ck0ut's Avatar
Are you ever going to boost it? Cause if so I wouldn't even go any higher then 4.10. I'd look at 3.90 or 3.73 in my opinion. 3.90 are PLENTY to get you off the line FAST. My first time ever at the track I launched from about 3k on my 315 555r drags and bogged and still hit a 2.006 60ft time which is pretty damn good for bogging and first time ever. Also do you research on them. I'd also like to point out that EXPECT gear whine that way if you don't have it then you'll be excited. I've had 2 different sets of gears and they both whine PERIOD. They are installed perfectly and still do it. Trust me, we've attempted to adjust it 3 times and it still does it and I got tired of buying oil. If your paying someone to do it make sure they know exactly what they are doing. I've heard a ton of horror stories with bad gear installs from shops that ruins the rear end due to bad bearing setups or reversed bearing caps.
t0t4lbl4ck0ut is offline   Reply With Quote
06:25 AM
