A noise from below... - Mustang Evolution
Old 07-27-2012, 11:57 AM   #1
daddydigest's Avatar
I just noticed that when going to some higher up gears like 3rd 4th, and 5th I get a fairly loud moaning noise that I can also feel. Ideas?
daddydigest is offline   Reply With Quote
Old 07-27-2012, 01:51 PM   #2
Re: A noise from below...
where does the noise sound like its coming from? Where do you feel the vibrations at?
southernstang00 is offline   Reply With Quote
Old 07-27-2012, 02:06 PM   #3
2Greeny7's Avatar
Send a message via Skype™ to 2Greeny7
Is it more or less around a certain RPM?
2001 V6
CAI, SF3/X3 Tuner, 4.10 Gears, Auburn lim-slip
GT4 Rims (Summer), Stock Rims (Winter)
2 Subs, New speakers all around
1 Great Car 1 Happy Kid
July '12 Mustang of the Month
2Greeny7 is offline   Reply With Quote
Old 07-27-2012, 06:06 PM   #4
jjsg09's Avatar
Could be rearend bearings or wheel bearings.
Old 07-27-2012, 07:47 PM   #5
LAS97GT's Avatar
Agreed, I have that prob. Sound travels up the drive shaft making it sound like a tranny or other when is not.
---Las97GT
Old 07-27-2012, 08:15 PM   #6
ward.r's Avatar
Listen closely see if u can hear it as a very low moan n second maybe first my car did that it was the rear end bearing and the housing that held my spider gears
ward.r is offline   Reply With Quote
Old 07-29-2012, 03:32 AM   #7
irishn8's Avatar
Also try wiggling ur wheels, if one seems a little loose, that's ur bad wheel bearing(s)
Old 08-06-2012, 05:40 AM   #8
Sorry for the delayed reply to the responses! When driving completely super-normal with no quick shifts or high revs is when I hear/feel it. I feel a shimmy/shake in the gear shift when it happens and hear the moan.
I had my rear diff repaired twice before in the past and this sounds different than with the constant noise with that. I have 208k on my 99 and never had a tranny issue and only replaced the clutch once around 106k.
Any more ideas or a simple way to check? Thanks again guys!
Old 08-07-2012, 01:51 PM   #9
Maybe a out of balance fly wheel or drive shaft?....im not sure how you could check those though.
---------- Post added at 02:51 PM ---------- Previous post was at 02:48 PM ----------
Bad Ujoint...im just throwing out idea....plantary gears in the trans? The only thing I can tell you is see if you can take to shop and put it on the lift while someone is on there shifting gears....and someone under it listen for something.
06:36 AM
