Steeda pulleys - Mustang Evolution
Old 07-30-2012, 09:48 AM   #1
jdavis96gt's Avatar
Region: West Virgina
Steeda pulleys
Just got some steeda pulleys on eBay. I was wondering if I needed anything for install? Like pulley puller or anything else. I want to be prepared for when they get here. Thanks for advice.
Old 07-30-2012, 09:55 AM   #2
CrookedHalos's Avatar
Think the hardest part is taking off the alternator pulley. Need some strength for that, people recommend taking it to a shop and have them use their air compressor tool.
CrookedHalos is offline   Reply With Quote
Old 07-30-2012, 10:06 AM   #3
jdavis96gt's Avatar
Re: Steeda pulleys
I got compressor and can get impact. I heard u needed a pulley puller.
Old 07-31-2012, 04:57 AM   #4
2002VertGT's Avatar
Yes you will need a crank pulley puller....u can rent one from advance auto
4.10 Gear/RPM thread
Old 07-31-2012, 07:39 AM   #5
jdavis96gt's Avatar
Re: Steeda pulleys
I talked to my neighbor and he going to let me use his puller. I got the pulleys for $80 new on eBay so I couldn't turn em down. They'll be here tomorrow .
Old 01-21-2013, 10:43 AM   #6
2002VertGT's Avatar
You still have the install bolt for your under drive pullies?
Old 01-21-2013, 10:48 AM   #7
jdavis96gt's Avatar
Somewhere. I try keep stuff like that. Why u need to use it?
Old 01-21-2013, 11:18 AM   #8
cliffyk's Avatar
I strongly recommend using a harmonic balancer installer because it means the threads in the cranknose will not be used actively to pull the pulley onto the shaft. Using the installation tool its adapter is threaded fully into the cranknose and it is the installer's threads that are actively loaded to "push" the pulley onto the crankshaft.
It also helps keep the pulley aligned squarely, and only costs a lousy $13...
Old 01-21-2013, 11:20 AM   #9
deadsp0t's Avatar
That's unimpressive
Old 01-21-2013, 11:25 AM   #10
jdavis96gt's Avatar
I couldn't get mine all the way on with bolt. It didn't feel safe. I rented pulley installer from autozone.
Ill let u use bolt but pulley installer makes it so much better.
Old 01-21-2013, 11:35 AM   #11
cliffyk's Avatar
At a point, using the installer bolt, you have to switch to using the real crank bolt--this is not "in-your-face" clear in the instructions. I have read of at least two people that jammed the installer bolt into the crank nose--one broke it off, the other stripped the threads in the crankshaft...
Old 01-21-2013, 01:46 PM   #12
2002VertGT's Avatar
Yes I do...
---------- Post added at 03:44 PM ---------- Previous post was at 03:43 PM ----------
Really...never heard of it...have to look into it as much as I pull harmonic balances off between my truck and car...
---------- Post added at 03:46 PM ---------- Previous post was at 03:44 PM ----------
That's fine I just need to install mine. I didn't know about the installer but the install bolt is only meant to push the HB in so far (to the point where the factory bolt can grab) then the factory bolt takes it home.
Old 01-21-2013, 02:29 PM   #13
jdavis96gt's Avatar
Remember 99-04 has special tightening sequence. Tighten to 66lbs, loosen one full turn, tighten to 37lbs, then tighten additional 90 degrees.
---------- Post added at 04:29 PM ---------- Previous post was at 04:25 PM ----------
Bolt is 12x1.5x60mm or 12x1.5x52.5mm.
Ill look for the bolt for u tho.
Old 01-21-2013, 02:32 PM   #14
cliffyk's Avatar
FWIW I have never been able to get the full 90°, with never an issue--65° to 70° is about the best I have been able to muster, even with a 24" breaker bar...
Old 01-21-2013, 03:02 PM   #15
jdavis96gt's Avatar
I found that bolt if u want to borrow it?
Old 01-21-2013, 03:05 PM   #16
2002VertGT's Avatar
Yes please I'll pm ya
Old 01-21-2013, 03:12 PM   #17
jdavis96gt's Avatar
Send it out Wed. Ill post just so u know its on its way.
Old 01-21-2013, 03:19 PM   #18
2002VertGT's Avatar
Ok just don't post my add y publicly...thanks man
Old 01-21-2013, 06:53 PM   #19
jdavis96gt's Avatar
I just remembered why I didn't use my bolt. Its wrong thread. My pulleys were advertised wrong (96-01). But there actually 01-04. I only used the crank pulley, since water pump pulleys different.
So I don't know if 96 is fine thread and 01+ is course thread. But my bolt is for 01-04 and course thread. Ill still send it just be careful. Maybe somebody will know if they're different.
Old 01-21-2013, 07:14 PM   #20
2002VertGT's Avatar
Well mines a 02...so it should work..
Old 01-21-2013, 07:18 PM   #21
jdavis96gt's Avatar
I just wanted to give u a heads up.
Old 01-21-2013, 07:26 PM   #22
2002VertGT's Avatar
Thanks!!
---------- Post added at 09:26 PM ---------- Previous post was at 09:25 PM ----------
Thanks!!
I'll compare bolts before I pull the pulley off
02:42 PM
