Does Weight Matter - Mustang Evolution
Old 07-30-2012, 09:57 AM   #1
infamous281's Avatar
Does Weight Matter
Weighed my car .. Roughly around 3300 .. Without my subwoofer in the trunk.
Is this a ideal weight?
Should I try to lose more weight?
Old 07-30-2012, 09:58 AM   #2
DaBluedude's Avatar
Weight spoils everything. If u can chop it do it.
2003 Mach 1
Old 07-30-2012, 10:03 AM   #3
Re: Does Weight Matter
every 120lbs is about like 10hp~ if you were to measure the two~
Old 07-30-2012, 10:14 AM   #4
The Blue Dragon
GrabberBlue5.0's Avatar
Always try to "add more lightness" to your car if it's possible
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 07-30-2012, 10:14 AM   #5
What would you recommend ?
I just have spoiler removed and uhm pretty much it Lol
Old 07-30-2012, 10:23 AM   #6
Gil_T2's Avatar
Weight affects every performance and ware value. Of coarse if your car is a DD then you could start to loose comfort if you take too much out. If you Heads Up race you need to loose as much as possible. If you index race doesn't matter. What do you want to do with the car?
BBK LT's, Catted Xpipe, Sniper tune, UDP's GT500 TB, Ford Racing CAI, CM delete, 4.10, TR6060, 1 piece DS
Gil_T2 is offline   Reply With Quote
Old 07-30-2012, 10:58 AM   #7
rotating mass is even worse, every 1lb of rotating mass is = 10lbs of dead weight~
Old 07-30-2012, 02:25 PM   #8
DaBluedude's Avatar
Stuff to take out includes spare, jack, rear seats. If you want to get serious about it replacing the front seats with aftermarket stuff. The stockers weigh a ton. I always recomend drilled and slotted rotors just for improved braking but it also lightens unsprung weight. If you have the chance upgrade to lighter forged wheels. An aluminum driveshaft and flywheel is a great upgrade as well.
Edit. Unless your serious about it I would say just take the spare and jack out and upgrade the front seats. The corbeau seats for our cars on american muscle are great.
2003 Mach 1
Old 07-30-2012, 02:33 PM   #9
most go with lighter wheels/tires, two piece rotors, alum driveshaft, etc for the biggest bang for the buck per lb dropped
Old 07-30-2012, 05:29 PM   #10
Wish my car was that light.
If you decide to get serious go k-member, tubular control arms, coil overs, chromoly rear control arms. Remove rear seat, gut trunk, remove pass seat. Would get you close to 3000 dry weight.
Old 07-31-2012, 04:04 PM   #11
Site Sponsor
Sponsor
AMWill's Avatar
SpectorV has great advice for easy and effective ways to cut some lbs. This is the most common approach people take for street/strip cars. 3300lbs isn't the worst either, but if you want improved performance in every category, weight is a good place to focus on.
Hope this helps!
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
01:35 AM
