manifold - Mustang Evolution
Old 07-30-2012, 02:03 PM   #1
foesublime's Avatar
manifold
My manifold cracked recently, I'm looking for a worthwhile replacement, I don't have a ton of money to do it, but I'd rather buy an upgrade then do a pull apart and have the same problem, do you guys have any suggestions? And possibly the bolt patterns for the manifold.
foesublime is offline   Reply With Quote
Old 07-30-2012, 03:48 PM   #2
BigB227's Avatar
Mine did the same and I was in a budget as well and after much advice and thought I decided to go with a stock replacement. It cost alot of money to get an aftermarket aluminum one and you need to buy a new throttle body or adaptor, new fuel lines and rails and it totals up. I've also heard that the aluminum ones get heat soaked after driving awhile so if your staying NA for awhile and it's a DD or close to it I would just recommend a stock PI replacement
BigB227 is offline   Reply With Quote
Old 07-30-2012, 03:51 PM   #3
Jlt00bluegt's Avatar
Get a ford replacement with the metal housing, nothing is better than the stock replacement until you are making some serious power or turning high RPM's.
Jlt00bluegt is offline   Reply With Quote
Old 07-30-2012, 03:57 PM   #4
foesublime's Avatar
Re: manifold
Would that ford racing replacement be my best bet so I don't have to go down the more expensive road of fuel rails and so on?
Old 07-30-2012, 04:00 PM   #5
Stockish302's Avatar
Besides stock I only use the edelbrock manifold with the elbow and the edelbrock fuel rails but that manifold is only good with boost or high revs I used it with the tfs2 cam and revved it to 7k
BBK cai, 96 tbird maf housing, BBK 70mm TB, TFS intake manifold, BBK shortys, bassani off road X pipe, Flowmasters with turndowns
If any one is willing to donate parts to the Make Joe's Mustang Faster that Corvettes Foundation, donations will be gladly appreciated
Stockish302 is offline   Reply With Quote
Old 07-30-2012, 04:04 PM   #6
foesublime's Avatar
Re: manifold
I am a noob with this stuff, so I'm looking for all the input and help I can get
Old 07-30-2012, 04:15 PM   #7
BigB227's Avatar
Yeah your bet bet would be the Ford Racing replacement, make sure when you get it that you get the one that says performance improved or PI
Old 07-31-2012, 05:37 AM   #8
jjsg09's Avatar
Here's AM they have it and they are great to deal with. Read all the description it tells you what you need and what to make sure to have to install this part. http://www.americanmuscle.com/intake-manifold.html
Ask some of the sponsors from AM on here about the forum discount. That will help if you.
Old 07-31-2012, 02:22 PM   #9
If I remember right I have one just laying around the garage that I'll sell you it came off my 2v that I turboed and did the edbrock swap on.
Old 08-01-2012, 08:22 AM   #10
Gobabygo67's Avatar
I decided to go with the ford racing manifold it was the same one as original but reinforced so it wouldn't warp or crack. In my case mine had warped
Gobabygo67 is offline   Reply With Quote
10:30 PM
