anyone see anything wrong with these plugs? - Mustang Evolution
Old 03-02-2008, 03:18 PM   #1
jimmy_beaner's Avatar
Region: Iowa
so I just changed my spark plugs, and being my first time, I'm not 100% sure what to look for. I know the plugs are "old" because I hadn't changed them before, and I've had the car for ~40,000 miles. I doubt they had been changed before this also. They have a purple end dot on the none sparking end. (a dot that would probably have come from a factory type environment... at least at the plastic factory I used to work at that's when we used it). So, I was wondering if there was anything wrong with the plugs? My car has 114,000 miles on it currently. All input is very welcomed
The car runs, which sort of surprised me considering I have never been "into" the engine with work before. Also, remembering to plug the PCV valve back in really helps (as it freaked me out hardcore). Anyway, I'm hoping to see that it runs better, and I have an oil change in the near future, as soon as I can find an area that isn't covered with snow and water.
Numbering goes as follows:
Passenger side front - 1, 2, 3, 4 - passenger side firewall
Driver's side front - 5, 6, 7, 8 - driver's side firewall
Name:	spark plugs all.jpg
ID:	18806   Click image for larger version
Old 03-02-2008, 10:07 PM   #2
sledgehammer's Avatar
Send a message via Yahoo to sledgehammer
Re: anyone see anything wrong with these plugs?
those are WELL OVER DUE for a replacement. the conductors things are done on em. They should have a flat top!!! thats scary to know those were in your car
94 v6 manual, 3.45s w/t-lock, cai, straight straight through dual exhaust, sct eliminator.
sledgehammer is offline   Reply With Quote
Old 03-02-2008, 10:17 PM   #3
Wow....
Old 03-02-2008, 10:17 PM   #4
Region: Iowa
I was told they were replaced just before I bought the car... that was about 40,000 miles ago. I'd say they clearly hadn't been. The car does run a lot more smoothly right now though.
Old 03-02-2008, 10:20 PM   #5
Region: Iowa
Wow....
haha, amazing the car was running a little rough huh? She runs real smooth now
Old 03-11-2008, 07:30 PM   #6
FLGT's Avatar
That's ALOT of carbon build up on the electrodes. What grade of gas are you running? Run some fuel injector cleaner thru her too.
2000 GT "Spring edition", 5 speed w\Ford Racing performance clutch w\Steeda high performance cable, billet clutch quadrant & firewall adjuster, Eibach Pro kit w\KYB adjustable shocks, o\r x-pipe w\Flowmaster American Thunders (no cats), Alpine CD\DVD\MP3 head unit w\JL Audio high\mid\subs, and carbon fiber all over the interior.
FLGT is offline   Reply With Quote
Old 03-11-2008, 07:43 PM   #7
Yea your car should run so much better now
Old 03-11-2008, 08:40 PM   #8
they lied.........thats probably the stock plugs. no wait, that IS the stock plugs. what did you replace them with?
Kyle is offline   Reply With Quote
Old 03-11-2008, 10:22 PM   #9
Region: Iowa
I replaced them with OEM replacements. The car runs much smoother now, idles better, and has a little better pick up. OEM replacements are pretty cheap... I'm just happy I did the swap without killing my car. Plus, those plugs NEEDED out. Wow, I can't believe they hadn't been changed in 114,000 miles.
Old 03-11-2008, 10:27 PM   #10
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
The color on them looks pretty good, though.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 03-12-2008, 02:13 AM   #11
Kiljosh's Avatar
Wow yea the electrodes are completely shot on those old ones haha. Enjoy the newfound power and gas mileage!
Old 03-12-2008, 06:35 AM   #12
Region: Iowa
my gas mileage has actually gone down. I was getting 22 mpg (down from 26 average when I got the car). I typically get 28-29 interstate, so we'll have to see what happens today. I should use about a half tank, and I'm curious to see what I get. I think my gas mileage went down because the ice and snow is finally melting, and therefore, I'm getting on it a lot more. Plus, it runs so smooth I don't notice my RPM's going up as much... used to have a terrible whine I couldn't stand so I shifted a lot earlier.
Old 03-12-2008, 07:09 AM   #13
my car runs smooth but I KNOW they need to be changed lol Ive got to get in gear and do it... I keep putting it off waiting on a pulley swap
Old 03-12-2008, 09:06 AM   #14
Region: Iowa
I was surprised at how quickly it actually went, especially being my first time. Passenger side seemed to take forever, especially the first couple. But the driver's side took like 10-15 minutes.
Old 03-12-2008, 12:47 PM   #15
Kiljosh's Avatar
I just hope you used the gell on them because it will make the next time 1000x easier.
Old 03-12-2008, 03:08 PM   #16
Region: Iowa
I used antiseize as well as this electrolytic slime you put on the coil end.
Old 03-12-2008, 07:50 PM   #17
rocknbronco's Avatar
They arent in the car......
Those should have been replaced a while back a long while ago.
rocknbronco is offline   Reply With Quote
Old 03-12-2008, 09:37 PM   #18
Region: Iowa
I was told they were replaced at 70,000 miles. Being the car now has 114,000, I figured they should be "ok"... apparently, the guy is a huge liar. So, now to flush all the fluids I can.
what am i doing wrong??? BigL34461 Pre-2005 V6 Mustang 10 09-29-2006 09:59 PM
best plugs bosscityboy86 1996-2004 Mustang GT 13 09-12-2006 06:11 AM
Am I wrong? 97Stallion The Bar 18 09-14-2004 05:12 PM
Crazy Vid, wrong place wrong time Black95GT The Bar 19 06-26-2004 03:38 PM
08:00 AM
