Driver side rear wheel bearing - Mustang Evolution
Old 08-05-2012, 08:15 AM   #1
10cches's Avatar
I have no clue how to change my driver side rear wheel bearing on my 2000 gt anyone have any ideas or no how step by step anything is better than nothing
10cches is offline   Reply With Quote
Old 08-05-2012, 08:30 AM   #2
jwhayne0001's Avatar
Remove brake and rotor, remove diff cover, remove center pin in diff, slide axle all the way in remove c clip, pull axle out remove axle seal, remove bearing, reverse to install and you will need diff fluid, and silicone and a new axle seal
jwhayne0001 is offline   Reply With Quote
Old 08-05-2012, 09:58 AM   #3
10cches's Avatar
How bad is it to but the bearing back in
Old 08-05-2012, 01:51 PM   #4
Not bad gently tap it in
05:23 PM
