Lowering question - Mustang Evolution
Old 08-06-2012, 08:24 AM   #1
Lowering question
So Im about to order up some lowering springs and I was looking at getting the H&R SS. Its a daily driver so im looking for a nice ride with good stance.
Is there anything else that I would need to buy along with these springs?
03DroptopGT is offline   Reply With Quote
Old 08-06-2012, 08:50 AM   #2
johnofarch14's Avatar
Send a message via Skype™ to johnofarch14
Caster camber plates......
johnofarch14 is offline   Reply With Quote
Old 08-06-2012, 08:55 AM   #3
Re: Lowering question
is that is?
Old 08-06-2012, 09:08 AM   #4
chickengeorge's Avatar
You should also get polyurethane spring isolators too.
chickengeorge is offline   Reply With Quote
Old 08-06-2012, 09:54 AM   #5
Originally Posted by 03DroptopGT
is that is?
Well if you want a perfect geometry in your suspension when you lower it, you need to change your balljoint, bumpsteer kit, shocks and struts... That's too much money... CC plates helps you correct your alignment when you use an H'R SS springs, that's all you need for now.. And the isolators that's correct...
Old 08-06-2012, 12:29 PM   #6
thanks guys!
Old 08-06-2012, 12:55 PM   #7
You are welcome!
05:28 PM
