Clutch Pedle hard to push down? - Mustang Evolution
Old 08-06-2012, 09:32 AM   #1
Scream's Avatar
I have an 02 GT when I push down the clutch it is beyond hard... My leg is sore the next day and i know I'm not THAT weak haha. It sounds like the throwout bearing is going bad to a winding sound. Any way to reduce the tension in the peddle or is it the Clutch itself?
Thanks-
Scream is offline   Reply With Quote
Old 08-06-2012, 02:23 PM   #2
Mile high JDF's Avatar
Its possible that the cable is stretched
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 08-06-2012, 04:18 PM   #3
infamous281's Avatar
Thanks-
Stock Cables always bust.. Get a adjustable cable kit .. It does wonders
Old 08-06-2012, 09:07 PM   #4
LAS97GT's Avatar
Naw, input shaft needs to be greased. Get some high temp grease that will last longer under high temp.
---------- Post added at 11:07 PM ---------- Previous post was at 11:05 PM ----------
Clutch is only as easy as the Tob is to move along the shaft.
---Las97GT
Old 08-06-2012, 11:05 PM   #5
Scream's Avatar
Thanks to all I'm replace the clutch throwout bearing and pressure plate and if that dosent work I'ma try these suggestions
Old 08-07-2012, 10:12 PM   #6
Mustang936's Avatar
My clutch pedal was hard to push down, I replaces the clutch and the cable, it made a world of difference
Mustang936 is offline   Reply With Quote
Old 08-08-2012, 03:10 PM   #7
Scream's Avatar
I'm changing clutch pressure plate and throwout bearing hopefully it'll help
Old 08-08-2012, 04:54 PM   #8
Silver Pony's Avatar
When my clutch got to hard to push the cable snapped. Check the cable. Unless you have noise, then probably the tob.
Silver Pony is offline   Reply With Quote
05:17 PM
