Running N/A cams with a blower - Mustang Evolution
Old 08-06-2012, 08:49 PM   #1
Bret21's Avatar
I have a kenne bell 1.7 that I plan on putting on my car. I have came across some trick flow stage 2 n/a cams for a great price and didn't know if it would hurt to put the blower on with these cams. Any advice would be awesome!
Thanks!
Bret21 is offline   Reply With Quote
Old 08-07-2012, 07:28 PM   #2
Mzilla's Avatar
What are the cam specs
Mzilla is offline   Reply With Quote
Old 08-12-2012, 08:41 AM   #3
ColeJohnson's Avatar
Re: Running N/A cams with a blower
Bump. What's the cam specs?
2016 Comp Orange GT (current)
Old 08-12-2012, 02:06 PM   #4
Bret21's Avatar
Not sure on the cam specs but someone told me if I didn't run a blower cam then I would lose boost out of my exhaust. Any idea what kind of blower cam I should run? Also where to order from?
Old 08-12-2012, 09:15 PM   #5
Trick Flow stage 2 cams are the same as the Crower blower cams. 234/580 lift.
8111870 is offline   Reply With Quote
Old 08-12-2012, 09:50 PM   #6
Bret21's Avatar
Even if the trick flows are made N/A? Is it going to hurt me if I run the trick flows with a blower? I've heard it will and some people say it won't
Old 08-12-2012, 09:59 PM   #7
CodyNelson's Avatar
Region: West Virgina
Below ~15psi most NA cams will work just fine with a blower setup
Old 08-13-2012, 08:31 AM   #8
Bret21's Avatar
So I won't be losing any boost if I was to put them in my car?
Old 08-13-2012, 08:12 PM   #9
CodyNelson's Avatar
You're losses will be so small you will never know it. There is a couple guys on here running them on blower applications running 500+ at the wheels
Old 08-14-2012, 09:25 AM   #10
Bret21's Avatar
Awesome. Well I might run these cams for a while until I find a blower that will give me the power that I want and then upgrade to blower cams. I'm not in a big hurry to do anything.
04:54 AM
