Gears - Mustang Evolution
Old 08-08-2012, 07:01 PM   #1
Vmcgrath's Avatar
Gears
Heard about gears and how they help with you mustang performance but I know a little about them
I bought a 96 mustang gt for parts for my 98 mustang gt well the guy I bought the 96 gt from told me it had some gears in it and I forget what type he said they was but the 96 is a 5speed and mine is a 98 automatic
Well I was wanting to know if I can get the gears out the 96 5speed and put it in my 98 automatic?
Vmcgrath is offline   Reply With Quote
Old 08-08-2012, 07:16 PM   #2
irishn8's Avatar
Well u really want to know what gears they are first. U have to make sure his differential is the same as urs. Stock I guess. U don't want 4.10 gears in ur auto unless u plan on taking to the drag strip often. I think most likely however, they are 3.73. That's what I have and I'm happy with that. If you do a lot of highway miles, that might not be what u want because u will see a decrease in mpg's, while an increase in low end torque. U also have to look at the length of the gear and weather or not it will fit ur diff.
Old 08-08-2012, 07:38 PM   #3
Vmcgrath's Avatar
Thanks for the help buddy
I do want to put gears in my mustang I just wanting to know because the guy told me he had some put in already so I was thinking hell if I have these gears in that mustang why not take them out and see if the work with my mustang instead of having to buy some and already have them in my back yard with that mustang
But I will take them out and see what happens and see if it's what I want
Thanks
Old 08-08-2012, 10:30 PM   #4
Re: Gears
Most people find that 4.10s are great for Autos and that 3.73s are great for manuals. It also matters on what type of driving you do. If you drive 90% city then you may actually see an increase in mpg, however if you drive mostly highway you will see it drop. And technically you do not gain any torque from gears, you simply are able to accelerate faster due to the gears. And gears from a GT will not fit a V6, so make sure if you are pulling them from another car it is the same model.
Old 08-09-2012, 08:56 AM   #5
Brad.krieg's Avatar
Send a message via Yahoo to Brad.krieg Send a message via Skype™ to Brad.krieg
+1. 4.10 for autos. And 3.73 for manuals. I had 4.10s in my 99 gt manual and it was fine. I saw maybe a 2 mpg loss... It doesn't affect any torque numbers but you will definitely feel it driving. Yeah, i'd go 4.10s. Especially only with 3 gears and an overdrive. Anything else lower would be a waste of money in my opinion.
Brad.krieg is offline   Reply With Quote
Old 08-09-2012, 01:00 PM   #6
Mile high JDF's Avatar
An easy way to check is to lift the rear end up with the car in neutral, mark the driveshaft with like whiteout and then try to mark a point on the wheel. Rotate the wheel 1 full rotation and count how many times the driveshaft rotates. The driveshaft rotating 3 1/4 times would be 3.27s, 3 3/4 would be 3.73s etc. The GT should have an 8.8 so it would be as simple as unbolting the axle and. Swapping it to your 98.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 08-09-2012, 01:38 PM   #7
Brad.krieg's Avatar
Correct. Sorry, i forgot this was the original question.
Should swap in just fine.
03:27 PM
