White face reverse glow gauge problem - Mustang Evolution
Old 08-09-2012, 08:26 AM   #1
9tee7pony's Avatar
Is the anyone who has put these on. I have them in, but I can't seem to get the reverse glow lights to work. I have it connected as the instructions state, but it still isn't working.
9tee7pony is offline   Reply With Quote
Old 08-09-2012, 09:16 AM   #2
BigB227's Avatar
I installed it awhile ago but took them off, there is a wire that they tell you splice into and it doesn't work you have to splice into another wire
BigB227 is offline   Reply With Quote
Old 08-09-2012, 09:34 AM   #3
9tee7pony's Avatar
What I ended up doing is getting a longer wire and grounding it to a screw under the dash and it works fine. It did freeze up a couple gauges though, luckily none of the really important ones though.
Old 08-09-2012, 11:04 AM   #4
Scream's Avatar
It shouldn't freeze them it did that to me it's an easy fix... Take the gages out and in the middle of them wear the needle goes through your slightly stretch them out the gauges are so tight that it stops the needle most likely
Scream is offline   Reply With Quote
Old 08-09-2012, 11:35 AM   #5
Matticus's Avatar
It's probably a ground problem. I ended up having the drill a small hole in the chassis to create a new ground, which was easier too because it was closer to the spliced wires so I didn't need to lengthen them much.
Matticus is offline   Reply With Quote
Old 08-09-2012, 11:55 AM   #6
9tee7pony's Avatar
That's all that I figured it was, but my fingers are torn to shreds right now so I'll let them heal and play with it then.
08:01 PM
