YEAH! another AC problem threat - Mustang Evolution
Old 08-09-2012, 04:04 PM   #1
bluekswiss_04's Avatar
I have never had any problems with the AC on my 2001 Bullit til yesterday, all of the sudden stopped blowing air. I disconnected the battery, and nothing, so I started playing with the AC knobs and when it got to MAX AC it would only blow really low, and it wont work on any other setting, any thoughts and suggestions will be greatly appreciate it,
thanks guys
bluekswiss_04 is offline   Reply With Quote
Old 08-09-2012, 04:07 PM   #2
BigB227's Avatar
thanks guys
Check to see If you can hear th AC clutch kick on and my ac stopped blowing cold but it would blow and it ended up being my CCRM
BigB227 is offline   Reply With Quote
Old 08-09-2012, 05:26 PM   #3
infamous281's Avatar
thanks guys
The switch on the airbox prolly came out..
Old 08-09-2012, 05:37 PM   #4
Re: YEAH! another AC problem threat
If your not moving,,and the low speed works,,you may have a bad fan resistor..But usually when you turn it to high it bypasses the resister and goes through a relay..I would pull out the resister and see if its burnt,,and make sure theres contunity through the little thermal fuse at the begining of the resister..
mymustang is offline   Reply With Quote
08:35 PM
