The stang is down :< - Mustang Evolution
Old 08-09-2012, 07:32 PM   #1
Arron's racecar's Avatar
Region: Nevada
I was on the way to work this morning when I went to let the clutch out at a light and then there was a noticeable clunk in the pedal followed by the most atrocious metal on metal squeal/ grinding noise I've ever heard coming from the tranny. I've known my clutch was on its way out the door( I could hear the TOB howling and the clutch slipping) and now the pedal doesn't feel as stiff and this noise is present at all times.( depressing the clutch pedal changes the noise but doesnt make it any better. What I'm concerned about is whether or not I'm looking at something much more pricey than a clutch swap? Any input would be apreciated.
2004 GT current mods : CAI, BBK Short throw shifter TB and UDPs, SCT x3/SF3 with BAMA Perfomance tunes Roush body kit, roush side skirt exhaust and paint.
Arron's racecar is offline   Reply With Quote
Old 08-09-2012, 08:04 PM   #2
maldog's Avatar
Region: Nevada
Re: The stang is down :<
IMA, if you keep on pushing something that is failing you may start to break other things and it just may end up costing you more and more $$$$$$ in the long run. The quicker you get something fixed the better.
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 08-09-2012, 08:09 PM   #3
Lorraine's driver
ab_mach1's Avatar
+1, hafta agree
Instagram: @ab_mach1
Old 08-09-2012, 08:17 PM   #4
Scream's Avatar
If it is making noises you could have to replace throw out bearing also.. I have to replace mine so I'ma switch pressure plate and clutch
Scream is offline   Reply With Quote
Old 08-09-2012, 08:25 PM   #5
Region: Nevada
I'm replacing the clutch with an exedy stage 2 clutch and matching light weight flywheel a ford racing TOB and pilot bearing. Any thing else I should be expecting to replace?
---------- Post added at 06:25 PM ---------- Previous post was at 06:23 PM ----------
Oh and I'm not driving the car anymore until this is fixed.
Old 08-09-2012, 08:40 PM   #6
Lorraine's driver
ab_mach1's Avatar
Sorry to hear that man. Hope you can get her fixed soon.
Old 08-09-2012, 09:42 PM   #7
Region: Nevada
Thanks, I'm planning to get the clutch swap done and have her running by the end of the month.
Old 08-09-2012, 09:44 PM   #8
Lorraine's driver
ab_mach1's Avatar
I'm always wondering what is a good aftermarket clutch. Has anyone given you any info on them?
Old 08-09-2012, 09:47 PM   #9
Region: Nevada
I have heard good things about ram, exedy, and centerforce. I'm going with the exedy stage 2 with light weight aluminum flywheel. FR pilot bearing and TOB from AM.
Old 08-09-2012, 09:49 PM   #10
Lorraine's driver
ab_mach1's Avatar
Do you know what a dual friction clutch is? That's the only one somebody recommended to me. I think it's a Centerforce.
Old 08-09-2012, 10:47 PM   #11
Region: Nevada
Dual friction utilizes 2 pressure plates
Old 08-09-2012, 11:13 PM   #12
Lorraine's driver
ab_mach1's Avatar
Thanks!
Old 08-10-2012, 12:11 AM   #13
Region: Nevada
Thanks!
No prob. that's about all I know about it in the first place lol.
Old 08-10-2012, 10:44 AM   #14
Mile high JDF's Avatar
A dual friction provides a much better clamping force while keeping a fairly light clutch feel. Usually people don't use them until they start hitting high horsepower numbers.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 08-10-2012, 10:50 AM   #15
Lorraine's driver
ab_mach1's Avatar
I'd kinda like the lighter clutch feel idea.
Old 08-10-2012, 10:57 AM   #16
Its pretty nice. My buddy has one in his GT500 and it drives really smooth
Old 08-10-2012, 10:59 AM   #17
Lorraine's driver
ab_mach1's Avatar
I have an aftermarket, but don't know the model. It's pretty heavy and grabs nearly instantly. Not so good for everyday driving.
Old 08-10-2012, 04:59 PM   #18
WheelStander's Avatar
Sounds like my heavy King Cobra clutch.
Induction: Kenne Bell | wHp: 515 Tq: 503 | 1/4 Mile:11.09@123
WheelStander is offline   Reply With Quote
Old 08-10-2012, 05:18 PM   #19
Lorraine's driver
ab_mach1's Avatar
It took me a while to get used to it, but there are still times where I make her jolt a little.
Old 08-10-2012, 05:24 PM   #20
Same here.
I would not do another King cobra clutch.
Old 08-10-2012, 05:29 PM   #21
Lorraine's driver
ab_mach1's Avatar
My buddy kept teasing me. Girl can't drive a stick! I let him drive it and he shut up.
Old 08-11-2012, 08:09 AM   #22
95v686gt's Avatar
I had a ram dual disc clutch in my fox. Was a heeeavy clutch. But it never slipped and never made a noise. But being stuck in traffic with that car sucked cause it was soo stiff!!
1995 V6 Mustang= Divorced Duals, Flowmaster 2 chambers, NO CATS, Raxiom Halo Projector headlights, Smoked Tails, 17 inch Bullitt Wheels
1997 Mustang GT: 4.6L DOHC http://www.mustangevolution.com/forum/f280/t305270/
1986 Mustang GT= Built 302 SOLD
95v686gt is offline   Reply With Quote
Old 08-11-2012, 10:21 AM   #23
Lorraine's driver
ab_mach1's Avatar
Do some make a metallic noise until they are warmed up? I know what answer I hope to hear
Old 08-11-2012, 11:24 AM   #24
95v686gt's Avatar
No it should be quiet no matter the condition
Old 08-11-2012, 11:29 AM   #25
Lorraine's driver
ab_mach1's Avatar
F! I'll have to keep my noise thread alive I don't wanna steal Aaron's thread. Sorry bro!
Old 08-11-2012, 01:41 PM   #26
Region: Nevada
Lol no problem. Just hope this helps the next poor SOB that runs into the same problem.
Old 08-17-2012, 01:28 PM   #27
Region: Nevada
Ok so the mustang is fixed the clutch was replaced yesterday but on the way home realized it sounded like it had an exhaust leak so I had to take it back and have them put the mid pipe back on correctly but other than that it's much better. The noise had been caused by the TOB seized up. It looked pretty bad.
ID:	64248   Click image for larger version
Old 08-17-2012, 01:37 PM   #28
Lorraine's driver
ab_mach1's Avatar
Glad your back up and running. Was it too bad costs wise, if you don't mind me asking?
Old 08-17-2012, 02:09 PM   #29
Region: Nevada
Nope install was 350$
Old 08-17-2012, 10:08 PM   #30
mcvicar04's Avatar
Be careful with a light weight aluminum flywheel they tend to warp and get heat spots on it much quicker
mcvicar04 is offline   Reply With Quote
Old 08-18-2012, 01:49 PM   #31
Region: Nevada
Didn't end up going with an aluminum FW. Just got a new iron one. Got a good deal on a ram clutch at summit.
02:55 PM
