03 gt hood scoop help! - Mustang Evolution
Old 08-11-2012, 09:00 AM   #1
Doe_Rae_mi's Avatar
Okay so I have a man that will fix the clear coat coming off my hood scoop. He said he would like for me to remove the scoop and bring it to him. What exactly is holding my scoop, screws or tape?? And would it just be best for him to fix my scoop while it is on the car?
Old 08-11-2012, 09:27 AM   #2
1slosix's Avatar
Re: 03 gt hood scoop help!
GT scoops are held on with 4 bolts and tape...he could mask it all off and respray it there
Old 08-11-2012, 11:29 AM   #3
Matticus's Avatar
It's really pretty easy to take off, or mine was anyways. Just need a rachet with a lengthener
Matticus is offline   Reply With Quote
Old 08-11-2012, 12:24 PM   #4
maldog's Avatar
Region: Nevada
Look under the hood and see if you have bolts with nuts, if not it's only being held on by tape. If only tape the best way to take it off is fishing line! Hold the line in each hand rapped around hand (gloves work best) then put it under one edge of the scoop and start working it gently back and forth until all the tape has been separated from the hood and then clean excess off. So even if you do have bolts the wire is still the way to go.
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 08-11-2012, 03:50 PM   #5
Bossshinoda03's Avatar
Well yeah it's easy to remove, just one thing they forgot to mention , you have to revoke the hood liner first, then you will see where to take it off.
---------- Post added at 04:50 PM ---------- Previous post was at 04:49 PM ----------
Stupid autocorrect, remove the hood liner first!
Bossshinoda03 is offline   Reply With Quote
Old 08-11-2012, 05:45 PM   #6
Doe_Rae_mi's Avatar
Thanks guys! I'm just really worried about putting it back on because idk if itll fly off while I'm driving
Old 08-11-2012, 08:47 PM   #7
BigB227's Avatar
It's held in by bolts, I've taken mine off a couple times so no worries about it flying off as long as you screw it back on
BigB227 is offline   Reply With Quote
03:22 PM
