i have a 98 gt 4.6 dohc with a tesked block - Mustang Evolution
Old 08-12-2012, 10:23 PM   #1
jas2705's Avatar
Region: West Virgina
What can i do to it and what will it handle. I want all motor power
jas2705 is offline   Reply With Quote
Old 08-12-2012, 10:46 PM   #2
CodyNelson's Avatar
If you are wanting to stay NA (all motor) then you will never have enough power to worry about blowing it. These motors are good for almost 500 at the wheels with the "safe point" in the 450 range.
As for mods, trick flow makes the best heads and comp 270 cams are one of the best on the market for stock GTs. You can also upgrade your intake manifold to the edlebrock one, and get a bigger throttle body and plenum. Then you have full exhaust and gears.
But just my 2cents, if you did all that above you would have $5000+ and only put down 370-380hp. If you spent $3000 on a cheap supercharger kit you will have less invested and be capable of pushing the motor to its limits and beyond.
Old 08-13-2012, 07:21 AM   #3
jas2705's Avatar
This is my first time building a ford ive always ran chevy i would like to get around 500. Out of it even it i have to go with a sc i just need some help with chosing the rite things so its npt goin to scatter the first trip out
Old 08-13-2012, 07:39 AM   #4
deadsp0t's Avatar
That's a SOHC set up or DOHC???
He has a DOHC.
That's unimpressive
Old 08-13-2012, 07:50 AM   #5
jas2705's Avatar
I have a dohc
Old 08-13-2012, 07:53 AM   #6
deadsp0t's Avatar
Originally Posted by jas2705
I have a dohc
You should be in the 280-315 flywheel horse power range to start out.
That's unimpressive
Old 08-13-2012, 12:06 PM   #7
jas2705's Avatar
So a set of cams and a pro charger should get me up around five ?
Old 08-13-2012, 02:29 PM   #8
95v686gt's Avatar
The teksid block can handle waay more than 500 hp. It will handle 1500+ without block mods. Pending what the engine came out of it could have a forged crank or not. Run your block numbers and make sure of what you got.
---------- Post added at 02:29 PM ---------- Previous post was at 02:20 PM ----------
Pics would be good also.
1995 V6 Mustang= Divorced Duals, Flowmaster 2 chambers, NO CATS, Raxiom Halo Projector headlights, Smoked Tails, 17 inch Bullitt Wheels
1997 Mustang GT: 4.6L DOHC http://www.mustangevolution.com/forum/f280/t305270/
1986 Mustang GT= Built 302 SOLD
95v686gt is offline   Reply With Quote
Old 08-13-2012, 03:28 PM   #9
jas2705's Avatar
It came in that car 98 gt dohc
Old 08-13-2012, 03:36 PM   #10
95v686gt's Avatar
It's not factory unless it's a cobra. Dohc came in mark 8's 94 to 98 and cobras 96 to 98.
Old 08-13-2012, 08:17 PM   #11
CodyNelson's Avatar
He has a DOHC.
Teksid block does not mean DOHC. Thousands of people use teksid blocks for 2V builds every day.
This. If your car has the factor motor you don't have a DOHC and you don't have a teksid block. Post a pic of the engine bay and I will tell you what you have
Old 08-13-2012, 08:22 PM   #12
jas2705's Avatar
Well its got a dohc in it and only has 70,000 on car im the third owner so im sure its factory
---------- Post added at 09:22 PM ---------- Previous post was at 09:19 PM ----------
How do u tell if its a teksid block
Old 08-13-2012, 08:23 PM   #13
CodyNelson's Avatar
Nah man. If it is a DOHC then you don't have a GT. And if it's a real GT then you either don't have a DOHC or it's not factory.
Old 08-13-2012, 08:26 PM   #14
jas2705's Avatar
Any way it is a dohc and ive always built chevys and older fords what up grades can i do to get around 450-500. Out of it
Old 08-13-2012, 08:38 PM   #15
95v686gt's Avatar
Go FI. About 8 psi of boost is a good start. Cams and heads headers mid pipe and cat back. Cold air kit tuner maybe a little nos. B heads are great for FI. Just run the block numbers and make sure of what you have.
Old 08-13-2012, 08:53 PM   #16
deadsp0t's Avatar
Regardless, man says it DOHC in the title and in his post..
That's unimpressive
Old 08-13-2012, 09:05 PM   #17
CodyNelson's Avatar
It also says GT. So one way or another this guy is wrong.
---------- Post added at 11:05 PM ---------- Previous post was at 11:03 PM ----------
People say DOHC instead of SOHC all the time. It's alot harder to mess up GT since it says it on the side of the car
Old 08-14-2012, 05:28 AM   #18
jjsg09's Avatar
Take a pic of the engine so we can see it!!!
Old 08-14-2012, 06:37 AM   #19
95v686gt's Avatar
Still say he needs to run the block numbers and see what he has...
04:40 AM
