Just a question - Mustang Evolution
Old 08-13-2012, 09:11 PM   #1
BigB227's Avatar
Just a question
So after installing my new PI intake manifold I started up my car and it has a real rough idle to where it kinda shakes the whole car and almost sounds like its missing or something i don't know. But I made sure that all vaccum lines and everything was plugged in correctly any suggestions?
BigB227 is offline   Reply With Quote
Old 08-13-2012, 09:12 PM   #2
Eturner's Avatar
A bad coil maybe!..
Old 08-13-2012, 09:21 PM   #3
BigB227's Avatar
Originally Posted by Eturner
A bad coil maybe!..
Yeah so how do I check? Do I just pull one by one until one is pulled and idle doesn't change??
Old 08-13-2012, 09:26 PM   #4
Eturner's Avatar
Run a scanner on your car!.. If you don't have one or a tuner then go to AutoZone and they can do it for free!.. But make sure all your coils are seated in properly too!..
Old 08-13-2012, 09:28 PM   #5
BigB227's Avatar
I have a tuner and it popped a code the said cylinder 4 injector circuit and I went and made sure the plug was all in and it went away for a lil then came back
Old 08-13-2012, 09:33 PM   #6
Eturner's Avatar
Then I think you just found your problem!.. As far as how to test a injector or the circuit I'm not sure on though!..
Old 08-13-2012, 09:49 PM   #7
BigB227's Avatar
Yeah me either lmao!!!
Old 08-13-2012, 11:09 PM   #8
02PONY's Avatar
Just unplug the cop if still the same plug it back in and unplug injector I had same problem and my injector wasn't all the way plugged in
02PONY is offline   Reply With Quote
Old 08-14-2012, 02:20 AM   #9
Watwoodjr's Avatar
Grab a can of crab cleaner start the car and spray it around the mating surfaces of your intake manifold if the idle jumps up it mean its a vacuum leak. To check if its a bad cop start the car and unplug one at a time if the idle changes the cop is good and if the idle doesn't change its a bad cop.
---------- Post added at 02:20 AM ---------- Previous post was at 02:17 AM ----------
Heres a link to a diy injector circuit tester.
http://forums.corral.net/forums/gene...t-circuit.html
Watwoodjr is offline   Reply With Quote
06:28 AM
