Foglights - Mustang Evolution
Old 08-14-2012, 11:44 AM   #1
Matticus's Avatar
Foglights
Bought some yellow fog lights not long ago and was going to put them on the other day, couldn't quite figure it out. It looked like I would have to take the front bumper off just to get to them. Is it easier than I'm making it or should I just take it to a body shop?
Matticus is offline   Reply With Quote
Old 08-14-2012, 01:37 PM   #2
v8pony's Avatar
Noooo very simple to DIY, Get on your back (if small like I am) and slide under the front bumper you will be able to see the back of the foglights, reach from under the car to the front of the bumper where the fog lights are and just twist and pull out, just did mine in about 30 seconds
2002 5spd GT
Feb 2013 Mustang of the Month
Old 08-14-2012, 01:40 PM   #3
beccabau2012's Avatar
are you talkin about replacing bulb are actual housing? both are fairly easy. just YouTube how to change housing or google how. they had a site a while back when I did mine that had pictures and described everything
beccabau2012 is offline   Reply With Quote
Old 08-14-2012, 05:53 PM   #4
v8pony's Avatar
Re: Foglights
i believe to replace the fog light housing is just as easy, on my 02 it looks like there is a screw in the top corner of the housing which must be removed, then the housing can move freely but wont pop out, on the bottom of the bumper there is a torx screw that seems is also holding the housing in, remove that and it seems it would just pop out, just reverse when putting new ones on.
07:24 AM
