Clutch adjustment question - Mustang Evolution
Old 08-15-2012, 09:15 AM   #1
Lorraine's driver
ab_mach1's Avatar
I need some help adjusting my clutch correctly. I still have the stock cable setup. I plan to buy a quadrant and firewall adjuster setup before winter hits, for now...
If the clutch is grabbing later (clutch pedal further out) than before, where should I make an adjustment at? At the tranny?
Instagram: @ab_mach1
Old 08-15-2012, 11:00 AM   #2
Lorraine's driver
ab_mach1's Avatar
*Bump
Old 08-15-2012, 01:01 PM   #3
Mile high JDF's Avatar
I don't think there's any real adjustment for them. You could do what the owners manual says to get it to readjust itself.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 08-15-2012, 02:28 PM   #4
Lorraine's driver
ab_mach1's Avatar
Thanks JDF. Yeah, I tried that, but I think that must be more for pedal slop. Hmmm, maybe the only way to adjust where you want it to grab is with an aftermarket quadrant and firewall adjuster...?
Old 08-15-2012, 03:02 PM   #5
I think that's the only way. Let me look around because I remember reading somewhere that you could try and bend a tab on the quadrant and that would kind of adjust it. But I'm not sire so I'll check if I can't find it again.
Old 08-15-2012, 03:05 PM   #6
Lorraine's driver
ab_mach1's Avatar
Thanks!
Old 08-15-2012, 03:07 PM   #7
Alright here's the article I read. I haven't tried it personally but I want to. http://www.corral.net/tech/drivetrain/clutcha.htm
Old 08-15-2012, 03:50 PM   #8
Lorraine's driver
ab_mach1's Avatar
Cool, thanks man! Looks like I need to speed up my purchase of a quadrant kit.
Old 08-15-2012, 04:12 PM   #9
No problem. Good luck!
Old 08-17-2012, 07:54 AM   #10
Lorraine's driver
ab_mach1's Avatar
Do any of you know if you can change the clutch quadrant without removing the entire pedal assembly?
Old 08-17-2012, 08:28 AM   #11
jjsg09's Avatar
Yes I've done a few and you dont have to remove the pedal assembly. It's just very uncomfortable to get to.
Old 08-17-2012, 08:57 AM   #12
Lorraine's driver
ab_mach1's Avatar
Cool, thanks man!
» Members Mustangs
G.L.
joe89
st577
st577
Add your Mustang
12:53 PM
