gears - Mustang Evolution
Old 08-16-2012, 09:15 AM   #1
Havixs's Avatar
gears
hi i was wanting a new gear set up and was wondering was a good one would be for a DD but i want to have some get up and go. i dont mind low gas mileage but dont want to be breaking the bank. just looking for some opinions.
Havixs is offline   Reply With Quote
Old 08-16-2012, 09:34 AM   #2
Re: gears
your stock ratio is 3.27 so a 3.73 would be the lowest noticeable jump while maintaining gas mileage. I think the change is 12% more acceleration but not 100%
4.10s are great but will eat up more gas of course. The faster the rpms climb the faster you get to shift thats another trade off.
Old 08-16-2012, 10:00 AM   #3
Havixs's Avatar
Re: gears
thanks for the info my is an auto.
Old 08-16-2012, 10:04 AM   #4
ColeJohnson's Avatar
Re: gears
With an auto your mpg won't change much, if at all, with 3.73s. With 4.10s(and proper auto-trans recalibration) you will get better MPGs in city, and go down about 1-4mpg on HWY if you drive nicely.
2016 Comp Orange GT (current)
Old 08-16-2012, 10:16 AM   #5
Havixs's Avatar
Re: gears
so 4.10 then and i have a basic concept of how they work but can u describe the details of how 4.10 work and 3.73 if you dont mind.
Old 08-16-2012, 12:46 PM   #6
Watwoodjr's Avatar
A 4.10 gear will have few rotations before the tires start to move vs the 3.73
Watwoodjr is offline   Reply With Quote
Old 08-16-2012, 12:52 PM   #7
Lorraine's driver
ab_mach1's Avatar
+1
Instagram: @ab_mach1
Old 08-16-2012, 12:57 PM   #8
Re: gears
Basically a certain gear-set is a torque-multiplier. Much like how pulleys act in a rope system, allowing the same force to do greater work on an object(such as a heavy item).
What a "3.73" or "4.10" gear means is that it takes the drivshaft 3.73turns or 4.10turns respectively in order to make the rear tires turn one complete rotation. The more turns the driveshaft makes per tire revolution the less power the engine has to put out to do the same amount of work. Therefore even though the power output of the engine hasn't changed, the mere fact it uses less power makes it seem like the engine produces more power because it uses it more efficiently. Therefore you get quicker acceleration.
Old 08-16-2012, 01:07 PM   #9
Havixs's Avatar
Re: gears
Thanks for the info and your time
Old 08-16-2012, 01:19 PM   #10
Mile high JDF's Avatar
Never mind
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
06:42 PM
