Getting 6MPG and Backfiring .. Please Help - Mustang Evolution
Old 08-17-2012, 07:15 PM   #1
infamous281's Avatar
Showing codes on my car
Getting O2 Sensor codes, and P161 Code ( Crankshaft Sensor )
I replaced my crankshaft sensor and it still showing the code.. Do you guys think I should replace my Camshaft sensors? Maybe.its all in a circle..
Its hard to start and sometimes back fires starting.. And I feel lose in power aswell..
Can someone please help me
Its costing me lots of money in gas and driving me crazy
Old 08-17-2012, 08:52 PM   #2
maldog's Avatar
Region: Nevada
Re: Getting 6MPG and Backfiring .. Please Help
Have you done anything recently to your vehicle? Anything at all?
That code is a wide spread basic code of P161 02 sensor.
Things to check for;
Vacuum leak
MAF sensor (clean it)
CAI (over oiled?)
That's rough bro. If I was there I could help you, but on something like this you have start doing the process of elimination. Good luck.
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 08-17-2012, 08:58 PM   #3
Slp_loudmouth's Avatar
When mine did that I threw the code for the 02 sensor ( no cats on the car though) and turned out to be my plugs. Doubt that would be it but just trying to help
Slp_loudmouth is offline   Reply With Quote
Old 08-17-2012, 09:53 PM   #4
Vacuum leak
CAI (over oiled?)
I added a Plenum/TB and a new filter and it started messing up..
I was going to clean my tb sensor and maf and then get ngk plugs and new cam sensor tommorrow.
Old 08-18-2012, 08:27 AM   #5
Bump
Old 08-18-2012, 08:39 AM   #6
maldog's Avatar
Region: Nevada
When this happened to me on my 06 all I did was clean and oil the filter. I put the filter back on and it started doing the exact same thing yours is doing. I cleaned the oil off the MAF sensor and tried to clean the filter, but it kept giving me the same codes. So I bought a new filter (CAI) and put it on. No problems after that. I cleared all the codes and it runs perfect and normal gas mileage.
Recommend;
1. Clean MAF
2. Clean TB
3. Put old filter back on
4. Clear codes
5. Start her up and see how she's running
---------- Post added at 07:35 AM ---------- Previous post was at 07:33 AM ----------
I can guaranty this problem is your filter!
---------- Post added at 07:39 AM ---------- Previous post was at 07:35 AM ----------
Please do the things I listed below before you go spend a bunch of monies.
Old 08-18-2012, 08:43 AM   #7
Recommend;
1. Clean MAF
2. Clean TB
4. Clear codes
Damn I threw away the old filter /:
But okay ill clean them first and see
Old 08-18-2012, 08:50 AM   #8
maldog's Avatar
Region: Nevada
I sent u a PM call me.
Old 08-18-2012, 08:58 AM   #9
Lorraine's driver
ab_mach1's Avatar
Also, If you done some work on it, double-check that you've got all the emissions, etc. connected correctly.
Instagram: @ab_mach1
Old 08-18-2012, 09:55 AM   #10
Well it started happening after I installed my plenum/TB
Old 08-18-2012, 10:36 AM   #11
95v686gt's Avatar
Bet you got a vacuum leak around your plenum and throttle body. Possibly something hooked up wrong. Double check there. Just for giggles did you check the gaskets? Use new ones or the old ones?
1995 V6 Mustang= Divorced Duals, Flowmaster 2 chambers, NO CATS, Raxiom Halo Projector headlights, Smoked Tails, 17 inch Bullitt Wheels
1997 Mustang GT: 4.6L DOHC http://www.mustangevolution.com/forum/f280/t305270/
1986 Mustang GT= Built 302 SOLD
95v686gt is offline   Reply With Quote
Old 08-18-2012, 12:13 PM   #12
Just took off everything and.cleaned all the.connections and hooked everything up
Put a fuel additive in it and put 5 Gals of 93 Octane
Bought a new cam sensor and replaced my crankshaft sensor
And still backfiring and not wanting to start.. I give up
Old 08-18-2012, 12:23 PM   #13
Voltage258's Avatar
Region: Utah
You cleaned all the connections, but did you clean your MAF sensor? And did it start doing it right after you put your new plenum and TB on?
If your getting good gas mileage, your not having fun.
Voltage258 is offline   Reply With Quote
Old 08-18-2012, 12:42 PM   #14
Lorraine's driver
ab_mach1's Avatar
Could the TB and/or plenum be damaged? Cracked or warped allowing leakage or unmetered air?
Old 08-18-2012, 01:03 PM   #15
Then why would it.be throwing crank/cam sensor codes and why would it be saying my timing is off ..
Old 08-18-2012, 01:08 PM   #16
Arron's racecar's Avatar
Region: Nevada
Vac leaks can cause alot of weird problems
2004 GT current mods : CAI, BBK Short throw shifter TB and UDPs, SCT x3/SF3 with BAMA Perfomance tunes Roush body kit, roush side skirt exhaust and paint.
Arron's racecar is offline   Reply With Quote
Old 08-18-2012, 01:23 PM   #17
Im about to just post it on craigs for 3000 and cut my damn losses..if its the timing chains then I just give up on this car . I just hadmy engine rebuilt 10k ago
Old 08-18-2012, 01:50 PM   #18
I had a few of our trucks in our fleet,,they are the 3 v 5.4 ,,had problems throwing a cam code and surging,,bad gas mileage..I ended up checking for a alternator a/c leak,,it had excessive a/c voltage,,and was interfering with the cam circuit...I know its a long shot ,,and these are newer,,but had several cases..I disconnected the wire off the back of the alternator and let it idle,,the surging went away,,and the code didnt come back..I think i had 42 volts A/C not DC coming across the battery..
---------- Post added at 01:50 PM ---------- Previous post was at 01:48 PM ----------
Also ask that TROJANHORSE,,guy thats on this site,,hes seems pretty smart
mymustang is offline   Reply With Quote
Old 08-18-2012, 02:02 PM   #19
95v686gt's Avatar
Put your stock tb and plenum back on and see what happens.
Old 08-18-2012, 02:27 PM   #20
Well I drove the crap outta it and turned my battery off for 16 min and now its not throwing any.codes and started up fine ? 0.o
Old 08-18-2012, 02:37 PM   #21
1996mustang's Avatar
It relearned itself. You probably added the parts and never reset the computer to relearn itself. Im also assuming its a stock tuned computer with no tuner so that would explain your backfiring and car running sluggish
Old 08-18-2012, 03:39 PM   #22
Lets hope to god.. Im heading home soon to go see
And yeah no tuner
Old 08-18-2012, 04:01 PM   #23
Lorraine's driver
ab_mach1's Avatar
That is definitely something you would want to do if you changed the TB and plenum. Idle relearn fuel trim. And you might have stumbled on the fix by disconnecting the battery for whatever other reason.
Old 08-18-2012, 05:14 PM   #24
maldog's Avatar
Region: Nevada
Recommend;
1. Clean MAF
2. Clean TB
4. Clear codes
I'm glad you fixed it
That was in step #4 way back in the beginning and when I PM you. Your wallet will be happy now
Old 08-18-2012, 06:30 PM   #25
Still throwing code ):
Old 08-18-2012, 06:40 PM   #26
maldog's Avatar
Region: Nevada
Damn
Old 08-18-2012, 06:41 PM   #27
Lorraine's driver
ab_mach1's Avatar
Dang!
Old 08-18-2012, 06:43 PM   #28
Damn
Could it be my altenator ?
I heard it can throw these kinda codes ..
Old 08-18-2012, 06:49 PM   #29
maldog's Avatar
Region: Nevada
I've never heard that bro. Have u done anything about the filter we talked about? Last ditch effort I guess?
Old 08-18-2012, 06:53 PM   #30
I dont have extra filter.. And its still new I got it like 3 weeks ago
Old 08-18-2012, 07:02 PM   #31
maldog's Avatar
Region: Nevada
Ok. You didn't oil it correct?
Old 08-18-2012, 07:02 PM   #32
Lorraine's driver
ab_mach1's Avatar
You could take the alternator off and have Autozone or the like check it. But, as maldog said, prolly not the prob. Maybe you PCM is the problem? Have you had a tuner flash a tune on this car before? Maybe the tune is jacked up.
Most important... Did it have these probs before you swapped the TB & plenum? Did it run okay when you first got it?
Old 08-18-2012, 07:13 PM   #33
maldog's Avatar
Region: Nevada
Also, is it the correct size as the one u had on it?
---------- Post added at 06:13 PM ---------- Previous post was at 06:02 PM ----------
Don't give up! Take a deep breath....we will figure this out.
Old 08-18-2012, 07:16 PM   #34
95v686gt's Avatar
Put the stock one back on. If it doesn't do it then suspect a problem with it. Also try doubling up on gaskets it still sounds like a leak somewhere.
---------- Post added at 07:16 PM ---------- Previous post was at 07:14 PM ----------
When you disconnected the battery it reset everything and it takes driving atleast 25 miles for it to fully relearn. What happened was the car went into relearn mode and ran fine til it settled. Now it's relearned everything the leak is showing back up..
Old 08-18-2012, 09:12 PM   #35
Smokedog's Avatar
My buddy has an 04 gt and had a similar problem you're having except he had a cam sensor code. It was backfiring and running poorly. We replaced the alternator and it solved the problem.
---------- Post added at 09:12 PM ---------- Previous post was at 08:50 PM ----------
Also he didnt get this cam sensor code until he washed his engine. So if you cleaned your engine lately this could possibly be your problem.
Smokedog is offline   Reply With Quote
04:41 PM
