weird grind. help please! - Mustang Evolution
Old 08-18-2012, 09:50 AM   #1
v8pony's Avatar
So when my car is cold and I hit 3k rpm I get a quick jolt grind that dissapears after a split second, now when the car is up to normal temp it will occasionally make the grinding noise at about 4k rpm same thing just for a split second than disappears, any ideas what could cause this ? It's driving me crazy! Appreciate any help thanks guys.
2002 5spd GT
Feb 2013 Mustang of the Month
Old 08-18-2012, 09:53 AM   #2
infamous281's Avatar
Whats done to your mustang and auto or standard ?
Old 08-18-2012, 09:54 AM   #3
maldog's Avatar
Region: Nevada
Re: weird grind. help please!
Maybe power steering pump? Bad belt tensioner? Have somebody listen with the hood up while u start it.
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 08-18-2012, 10:19 AM   #4
v8pony's Avatar
Pretty much stock, 5 speed manual....it can't be heard when started, if I rev it up it doesn't grind it has to be driving
---------- Post added at 12:19 PM ---------- Previous post was at 12:08 PM ----------
I'm new to the world of working on cars but trying to get there , so please bare with me if I get a little lost
2002 5spd GT
Old 08-18-2012, 12:46 PM   #5
Arron's racecar's Avatar
Region: Nevada
Is it a loud grinding noise? Where does it sound like its coming from. Since its only doing it while driving it may be a chattering clutch or failing throw out bearing. I just replaced my clutch and bearing but before it would make a slight grinding noise while in gear and driving and got worse at higher speeds.
2004 GT current mods : CAI, BBK Short throw shifter TB and UDPs, SCT x3/SF3 with BAMA Perfomance tunes Roush body kit, roush side skirt exhaust and paint.
Arron's racecar is offline   Reply With Quote
Old 08-18-2012, 06:30 PM   #6
v8pony's Avatar
Hmm I'd say yes it's noticeable inside with windows closed so it's gotta be a bit loud, the TOB could be it, I had a noisy TOB when the clutch was out and it went away when I pressed the clutch in, well I adjusted my clutch with the help of another member and the TOB stopped squeaking but the grind is still there, the grind has always been there even before I adjusted the clutch.
2002 5spd GT
Old 08-20-2012, 07:04 AM   #7
v8pony's Avatar
Bump
2002 5spd GT
Old 09-17-2012, 04:29 PM   #8
v8pony's Avatar
any ideas? still doing this? could it be with TOB? never heard of a TOB making a metallic grind noise
2002 5spd GT
Old 09-17-2012, 07:09 PM   #9
02 360R's Avatar
Is it only when you're driving? And never sitting still?
02 360R is offline   Reply With Quote
Old 09-17-2012, 07:33 PM   #10
v8pony's Avatar
Yes! At the specific rpm range, a little over 3k when cold, and sometimes a little over 4k when up to temp.
2002 5spd GT
Old 09-17-2012, 09:58 PM   #11
irishn8's Avatar
Need more details. Try to describe it as best u can. Is it loud enough u could make a recording? Is it a metalic grind or a low grumble or? Does it jerk the car or do u feel a slight pull? Try to describe it so someone who has never heard it before would know exactly what u mean. Compare it to something. Also has it gotten worse? Did anything significant happen just before you started hearing it? Any ditail you can think of might help us.
Old 09-18-2012, 06:05 AM   #12
v8pony's Avatar
I can probably get a recording but has to be first thing in the morning when it's dead cold I will try the next few days....IT IS a metallic grind not a grumble or anything, DOES NOT jerk or pull the car, its not the type of noise it makes when you grind a gear
2002 5spd GT
Old 09-18-2012, 06:21 AM   #13
02 360R's Avatar
Here's a theory: when you park the car for the evening and come to a stop, the brakes are applied-the brake pads are compressed against the rotors. Maybe the calibers are not releasing as they should and the pads are not in the best shape and creating the grinding sound you hear when the car is in motion. Bad brake pads makes a grinding sound as they carve into the rotors. Just a thought...
Old 09-18-2012, 07:20 AM   #14
v8pony's Avatar
Hmmm I do believe I have something going on with my front brakes too but would the brakes grind ALWAYS at that specific rpm range, I'd just find it a bit weird if it always grinds at a certain rpm range when cold than a certain rpm range when up to temp
2002 5spd GT
Old 09-18-2012, 10:00 AM   #15
02 360R's Avatar
I don't know. That is strange to hear it at certain RPMs. Maybe it is something else. Check your moving parts. Water pump, alternator, etc... anything that moves. Maybe the higher RPMs causes stress on one of those parts and makes the grinding sound. Just a thought...
Old 09-18-2012, 10:23 AM   #16
Lorraine's driver
ab_mach1's Avatar
Is it making the noise at the RPMs you mentioned under load, meaning your getting on it?
---------- Post added at 12:23 PM ---------- Previous post was at 12:20 PM ----------
If will not necessarily repeat if you were to slowly increase your RPMs, but it will if you get on it, it could be your clutch slipping some and chattering.
Instagram: @ab_mach1
Old 09-18-2012, 11:34 AM   #17
v8pony's Avatar
I'm pretty sure it does it either way, if I get on it or if I'm just slowly accelerating but when I hit the rpm range it does it, but I will have to re check when I get home,when I'm off work the car will be very cold so I will take it out and let you know..but from what I remember it does seem to sound a lot worse when im really getting on it.
2002 5spd GT
12:56 AM
