Need info - Mustang Evolution
Old 08-18-2012, 11:17 AM   #1
03 gtmustang's Avatar
Need info
I just had my oil changed about a week ago , went to check it to see if they put enough in it and the oil smell like gas .i was told that my car is running rich , any info would be helpful.
03 gtmustang is offline   Reply With Quote
Old 08-18-2012, 11:51 AM   #2
maldog's Avatar
Region: Nevada
Re: Need info
Assuming you're running injectors: Put a rail pressure gauge on and watch the 'hold' pressure. If you're injectors are leaking, there's only one place for the gas to go and that's into your cylinders, past the rings and into the pan.
This is actually a safety feature. Instead of the fuel leaking all over your engine and causing a engine fire it goes into your oil. You need to fix this ASAP! Your oil is being diluted and oil pressure drops.
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 08-18-2012, 12:05 PM   #3
Ok how do i fix it , and cost
Old 08-18-2012, 12:12 PM   #4
maldog's Avatar
Region: Nevada
Re: Need info
You need to do the fuel rail pressure hold test and see what side is leaking and replace injectors as required. The cost $$$ will vary.
Old 08-18-2012, 12:14 PM   #5
Ok thank you
Old 08-18-2012, 12:18 PM   #6
maldog's Avatar
Region: Nevada
Re: Need info
If you're not sure how to do it try to find a good shop at a good price. If you continue to drive it that way the fuel is diluting your oil and you will burn up bearings on your crank shaft.
04:48 AM
