96 mustang gt rough idle - Mustang Evolution
Old 08-18-2012, 11:38 PM   #1
Mitchel3408's Avatar
After filling up at a gas station and being in the highway for a little while I noticed my mustang started idling rough and it was running around 600-700 rpms.. My brother filled up at the same gas station and his car died after sitting at a stop light and then was idling bad but is now running fine.. I thought it was bad gas but I ran all that gas out and also put HEAT in to get water out if there was any in there. It will idle fine bouncing between 1300-1000 rpm and then will bog down. Any ideas why it is doing this?
Mitchel3408 is offline   Reply With Quote
Old 08-19-2012, 06:45 AM   #2
jdavis96gt's Avatar
Region: West Virgina
Re: 96 mustang gt rough idle
Just unhook ur battery and see if that helps.
Old 08-19-2012, 07:12 AM   #3
93slowstang's Avatar
Sounds like your car is in need of a tune up.
Old 08-19-2012, 09:20 AM   #4
Scream's Avatar
It could be the IAC (idle air control) sensor it may need cleaning be very careful the sensor is VERY sensitive take it to a pro to test it. Or it can even be a loose vacuum tube.
Scream is offline   Reply With Quote
Old 08-19-2012, 09:52 AM   #5
Where is the IAC located? And what can I use to clean it?
---------- Post added at 09:52 AM ---------- Previous post was at 09:50 AM ----------
I tried that and it didn't make a difference
Old 08-19-2012, 09:54 AM   #6
Scream's Avatar
It's connected to the throttle body and cleaning i don't know
Old 08-19-2012, 10:00 AM   #7
Ok. I'm pretty positive the guy I bought the car from had already replaced the IAC because it was idling rough. I've only had the car a few months, could it have gotten that dirty or gone out that fast?
Old 08-19-2012, 10:09 AM   #8
Scream's Avatar
Anything is possible but I doubt it maybe a loose vacuum tube
Old 08-19-2012, 10:18 AM   #9
mustang06gt's Avatar
Sounds like the guy just wanted to get rid of a problem and not really fix it himself.
2 options:
-Keep replacing items and spend a lot of money and time trying to figure it out. Not to mention the headache of it all, and the chance of creating more of a problem.
-Take it to a shop and let them figure it out for no more than 60.00.
---------- Post added at 12:18 PM ---------- Previous post was at 12:16 PM ----------
Not a dealership though. A shop that has been around for at least 10 years.
mustang06gt is offline   Reply With Quote
Old 08-19-2012, 10:52 AM   #10
Ok I'll check it out
08:56 AM
