Need some help - Mustang Evolution
Old 08-19-2012, 01:06 AM   #1
Bballing0416's Avatar
Need some help
Hey everyone....well turns out that my O-ring keeps popping out and gas leaks are occurring under the hood....i think my fuel rail has a crack in it....any ideas???
Bballing0416 is offline   Reply With Quote
Old 08-19-2012, 03:47 AM   #2
Rm360's Avatar
Do you still have stock fuel rails or do you have aftermarket ones ?
Old 08-19-2012, 10:10 AM   #3
infamous281's Avatar
I have the same problem when I take mine off.. Just bend it if you have too. Auto parts stores should have new o-rings
Old 08-19-2012, 11:00 AM   #4
Stock fuel rails with 39lb FR injectors
Old 08-19-2012, 11:25 AM   #5
Lorraine's driver
ab_mach1's Avatar
Do they pop out of the rails or the engine?
Instagram: @ab_mach1
Old 08-19-2012, 02:14 PM   #6
Well i found out is either the fuel rail is bent or has a crack on it or the fuel injector is defective
Old 08-19-2012, 02:27 PM   #7
Lorraine's driver
ab_mach1's Avatar
Glad you figured out what was going on.
Old 08-19-2012, 02:57 PM   #8
Stock rails blow
Dont get BBK rails they arent worth the money either I heard mmr makes good ones
Old 08-19-2012, 06:29 PM   #9
CodyNelson's Avatar
Region: West Virgina
Honestly the stock rails are fine. Just get an oem replacement. That way you only have to buy one instead of a whole new pair. The stock ones are good for over 600hp
Old 08-19-2012, 10:29 PM   #10
Well its fixed now so when it leaks again i will know forsure if its the fuel rail or injector
09:33 AM
