Rich on right and left bank - Mustang Evolution
Old 08-19-2012, 02:38 PM   #1
Brake.handle's Avatar
Region: Utah
Hey guys I'm at a loss I have codes saying I'm running rich on the right and left bank so I changed my MAF and fuel pressure regulator and still the same codes what else is there I need to change?
Brake.handle is offline   Reply With Quote
Old 08-19-2012, 02:44 PM   #2
Cobrarunnin9s's Avatar
Re: Rich on right and left bank
Have you checked your O2 sensors and for a leak after the mass air?
Cobrarunnin9s is offline   Reply With Quote
Old 08-19-2012, 02:57 PM   #3
Region: Utah
I haven't checked my o2 sensors but I know there is no leaks around my MAF. How would you check your o2 sensors?
Old 08-19-2012, 02:59 PM   #4
infamous281's Avatar
Just tighten them !
Old 08-19-2012, 03:25 PM   #5
If you have a scanner..you can snap your throttle,,they should go high on the numbers like 700 or higher millivolts,,then it will go low about 100 millivolts..Not sure what year that is,,but if you have a o2 on each bank,,unlikely both is bad at the same time..Do you have a evap purge on you car,,if you do ive seen them get stuck in the open position..Make sure there is not any air restrictions ,,like the air filter dirty..Is your car idling ok ,,sometimes a stuck idle air can cause that too..I have seen a dripping injector on one side,,cause the computer to throw both sides even though the problem is only one side
mymustang is offline   Reply With Quote
Old 08-19-2012, 04:48 PM   #6
Region: Utah
I have a 97 GT it seems to idle good and it has a brand new air filter but on occasion it will smoke and it smells like oil
02:28 PM
